I need to get a 160mm caliper (post) on to the fork (IS) will this adapter do it? http://www.chainreactioncycles.com/Models.aspx?ModelID=13735
I also need to convert the rear IS to post, so I need the same adapter again?
Posted : 06/08/2009 2:14 pm
That is not the one. What size rotors are you planning to run?
Posted : 06/08/2009 2:33 pm
160 on both ends.
Posted : 06/08/2009 2:34 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13743 ]Front[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13749 ]Rear[/url]
If you use the front adaptor on the rear it would be spaced for a 140mm disc.
Posted : 06/08/2009 2:39 pm
Cheers Chap! Have some good Karma 😉
Posted : 06/08/2009 2:44 pm
