Brake adapter quest...
[Closed] Brake adapter question
[#8095709]
Looking to increase to a 200mm rotor upfront and swap the current 180mm onto the rear of my t-130 but not entirely sure which adapter I need.
Also is it a simple case of swapping the existing 180mm front adapter onto the rear?
Sram guides on Rockshox pike if it makes a difference
Posted : 07/10/2016 2:04 pm
Unfortunately u can't switch adapters between front and back.
Posted : 07/10/2016 2:32 pm
Yes you will take your 180 Post of the front and put it on the back (assuming your rear is currently 'native' at 160mm) and then add a 200 to the front. EDIT: BTW the longer bolt end goes up on the fork and at the front on the rear (so kind of the same way).
Posted : 07/10/2016 2:34 pm
Pretty sure you can't put a front adapter on the back. I've tried it and it didn't work (the offset is all wrong ) Also, the ones u buy are always specifically marked "front" or "rear".
I could be completely wrong though.
Unless you've got IS front (rather than post). Then, they might be interchangeable.
Posted : 07/10/2016 3:12 pm
"[i]I could be completely wrong though.[/i]"
You reckon ?
Posted : 07/10/2016 3:21 pm
Given that the t-130 probably has rear post mount brakes, I'm gonna go with "I'm likely wrong" and say no more on the matter.
Posted : 07/10/2016 4:08 pm
