Brake adapter quest...
[Closed] Brake adapter question
[#6649594]
Just building up a bike
Not all parts here yet
Have 2 160 discs arriving and was wondering if I'd need an adapter to fit the caliper to this size disc?
Fork is new style (post mount?) but cant seem to find a post to post 160 adapter. Is this because it won't need one on the front for that size disc or I'm a bit useless searching? They all seem to be for 180 discs and upwards
MM
Posted : 20/11/2014 11:07 pm
The calliper should just bolt straight on at 160 iirc.
Posted : 20/11/2014 11:10 pm
yup. Caliper should go straight on for 160mm disc on the fork.
Posted : 20/11/2014 11:11 pm
Pretty sure the standard fork post mount takes a 160mm rotor without an adaptor, then you get adaptors to take it up to 180/203 etc.
However, some forks do take different size disks by default (e.g. 180mm/203mm)
EDIT: Too slow 🙁
Posted : 20/11/2014 11:12 pm
Perfect, thanks guys
Posted : 20/11/2014 11:13 pm
You'll likely need an IS/post +20mm, as rear calipers are 140 without adaptor/mount
Posted : 20/11/2014 11:17 pm
My 2010 Kula was 160 rear post mount. Guess some might do that to cut down on costs.
Posted : 20/11/2014 11:33 pm
Frame is a Yeti ARC Carbon, post mount rear. Can't really tell until the discs turn up
Posted : 20/11/2014 11:36 pm
