Brackets for attach...
[Closed] Brackets for attaching mini pump to seat posts?
[#3941938]
I've got a think barrelled Blackburn mini pump, which comes with a bracket to attach it to the water bottle cage mounts.
However my Anthem X is too square tubed for the bracket to fix (plus I want to use a water bottle)
Are there any brackets that you can buy to attached pumps to seat posts?
Ta
Posted : 04/05/2012 9:37 am
How about this?
http://www.xcracer.com/shop/viewproduct.php?productid=205
Posted : 04/05/2012 9:41 am
HOW MUCH!!!! for a velcro strap. Jezus wept!
Posted : 04/05/2012 9:44 am
Agreed- its a good idea though...
Posted : 04/05/2012 10:11 am
I guess these would work as an option, by raising the bracket away from the frame. Any one got a decent drill and lumps of Alloy lying around and want to drill me some 🙂
Posted : 04/05/2012 10:26 am
They just look like V brake spacers?
I've got some lying around if you want them.
Posted : 04/05/2012 10:29 am
Ah now theres a thought, will look at my box of stuff over the weekend!
This is where they came from http://activesport.co.uk/shop/article_2195/Wheels-Manufacturing-Front-derailleur-water-bottle-cage-spacer---aluminium.html?shop_param=cid%3D209%26aid%3D2195%26
Posted : 04/05/2012 10:33 am
Just bang it in your back pack
Posted : 04/05/2012 11:11 am
"Just bang it in your back pack"
I'm not using a back pack, its more for racing. Besides which, when I do use my back pack its only a nice small Camelbak which it can fit in but only just.
Posted : 04/05/2012 11:16 am
I've got all sorts of old pump mounting thingies in my shed that have never been used (cuz I use a Camelbak). Got any measurments? I wouldn't want anything for them. I'm sure others have too...
Posted : 04/05/2012 11:55 am
You can get co2 canister holders that strap onto the seatpost that would probably hold the pump.
Posted : 04/05/2012 12:46 pm
*OFF TOPIC* breatheasy - speaking of adaptors, did your mate ever find a solution to the Suntour fork mudguard mounting problem you posted about a year ago?
Posted : 09/05/2012 8:41 pm
+1 for the spacers - use a few washers if the spacers can't be found.
Also, having the pump bracket mounted on the bottle cage holes doesn't stop you from mounting a bottle cage too - you just need long enough bolts - that's how mine is mounted.
Posted : 09/05/2012 9:46 pm
