Looking for simple explanation....
My bike was shipped with a BB92 bottom bracket, with e13 TRS cranks (that need replacing).
If I go for SRAM kit, do I need a GXP bottom bracket? And just make sure I get a 92mm version? Really confused about BB Standards currently.
Looking for a fairly cheap 30t single ring bottom bracket and crank option.
I just bought an old frame with bb92 ans it had sram cranks on it before. To fit my shimano cranks I had to install 1mm top hat seals to take up the gap that the old gxp cranks had left. So on that basis I think you do need a gxp 92mm pressfit bb.
something like this is well worth considering:
[url= http://wheelsmfg.com/bottom-brackets/bb86-92/bb86-92-bottom-brackets/bb86-92-outboard-abec-3-bb-for-24-22mm-sram-cranks-black.html ]http://wheelsmfg.com/bottom-brackets/bb86-92/bb86-92-bottom-brackets/bb86-92-outboard-abec-3-bb-for-24-22mm-sram-cranks-black.html[/url]
uses angular contact bearings and good sealing- stock SRAM uses radial bearings with poor sealing = short life and constant replacement
yes you need a gxp 92mm press fit bb.
My frame came with a kcnc one which seems to get pretty good reviews. God knows how you remove it though.
Thanks. Almost clicked "buy" on a GX crankset before realising it was Boost 148 and so needs its own specific cranks.
Jeez, swear this used to be easier....
