Bottom Bracket inst...
[Closed] Bottom Bracket installation question.
[#2301377]
I just watched the Hope Tech installation video and when they replaced the bottom bracket they left the black plastic thing holding the two cups together on.
I bought a second hand chainset and this bit wasnt included, does it matter? I just fitted both cups and thought that was fine.
I've never fitted a BB before and I'm worried it does something important.
Does it actually do anything?
Posted : 20/12/2010 11:00 pm
Not essential, but it helps prevent dirt and water that accumulates in the BB shell getting to the bearings from the inside.May be a good idea to drill a 3mm drain hole in the shell.
Posted : 20/12/2010 11:03 pm
what he said not sure about the drilling bit though
Posted : 20/12/2010 11:10 pm
Ah, ok thanks. Think I'm gonna get a Hope BB so I'll leave it on this time.
BTW - if the second hand one is still OK you can get replacement center tubes:
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=36410
The image says DH but you can get all of the tubes via a webshop/LBS
Posted : 21/12/2010 8:25 am
Depends on your frame. Are there any holes in the bottom bracket where much and water can enter? I'm with coatesy, if it can get in, give it a way out again. I drill my frames.
Posted : 21/12/2010 8:58 am
im gonna pick up a Hope stainless steel tomorrow so ill stick it in, really don't want to start drilling my frame. Im lethal with power tools.
Posted : 22/12/2010 12:34 am
