Bottom Bracket comp...
[Closed] Bottom Bracket compatibility
[#9373318]
I've a Genesis Croix de Fer 10 which came with a square taper BB. The drivetrain is shot so I'm replacing all that but while I'm at it can I remove the BB and replace it with a Hollowtech II BB? A quick search seems to suggest I can. - I know the crankset won't be compatible but that's getting replaced as well so not an issue.
Posted : 09/06/2017 11:00 am
Hollow tech 2 is threaded so you'll be fine. Just make sure the threads match. Yours will be British threaded.
Posted : 09/06/2017 11:03 am
Yes.
Posted : 09/06/2017 11:04 am
Thanks guys
Posted : 09/06/2017 11:08 am
Standard 68mm BSA bottom bracket shell - the only type of crank that you'd have trouble with is BB30, virtually everything else is compatible.
Posted : 09/06/2017 11:10 am
The main "problem" is actually whether to stick with nine speed or move to ten speed. The problem is really one of cost as I'd need a new shifter if I moved to ten speed. Since it's my commuter/winter bike I'm not that fussed really, it would be nice if it was ten speed as then all my bikes would be compatible.
At the moment it will cost £170 to replace everything (BB, crankset, chain, derailleur, cassette), well apart from a new rear wheel 🙄 which is also on its way out so might as well do that at the same time. A new set of shifters adds £70 or so.
Posted : 09/06/2017 11:17 am
Just do it all, buy a complete Tiagra or 105 groupset and then just sell the bits you don't need, it'll almost certainly work out cheaper.
Posted : 09/06/2017 11:20 am
