Hi all
I'm fed up of having a part filled bladder on shorter rides so bought a whyte branded cage from whyte for my whyte G150 and guess what? I can't get the bottle in so it's useless!
Can anyone recommend a solution or has the same bike as me and has found a solution?
No big deal if not just wanted the option to be there if I needed it!
Cheers in advance!
Spesh Zee side entry cage.
^ +1
Yes , side entry cages best. I got one £12 from my LBS so probably cheaper online.
You could write whyte on the spesh zee in felt tip.
Fabric bottle might work depending on how far up the bottle the slots are.
Or you could try this, at £1.39?
http://www.chainreactioncycles.com/elite-nane-side-bottle-cage/rp-prod145186
Zee. Brilliant.
