HI,
We've got a cube acid ebike that has the bosch performance line cx motor on. Its been great so far but has developed a "squeak" under either very little or high load - seems ok when your pedalling normally. Has anyone else had this?
Chris
Posted : 24/02/2021 3:25 pm
Have you ruled out anything else that might be causing it?
I assume you've tried it with the motor switched off and it goes away?
Is it still under warranty? if so then straight to Bosch service centre...
Posted : 24/02/2021 6:01 pm
