Bos Vip'r Shoc...
[Closed] Bos Vip'r Shock Help
[#3343241]
Hey guys just a quick question about the bos vip'r shock. I have been told I need to pressurize the secondary chamber to get the shock to perform properly as I cant seem to get the rebound slow enough or the compression hard enough. It has been properly tuned by r53 for an orange 5 so any help would be much appreciated.
Posted : 11/11/2011 11:11 pm
To equalise the + and - chambers, put about 100 psi in and gently compress the shock about 15mm 10 times, then pump it up to 130 psi and repeat, then 150 and so on up to your desired pressure.( You can probably put a greater amount in each time)
I've found running 30 - 40 % sag works best for my bike but it might be different on a 5. Took a while to set up but it's great now.
Posted : 11/11/2011 11:25 pm
