You know, the ones that go over the pedal axel before you screw it into the crank.
I need some, and I thought I'd nip into a local hardware emporium, or Halfords, to see if they had anything that would work.
Can anyone help with the size (inner and outer diameter)?
the thread is a nominal 9/16" IIRC.
Actually, I've done you a favour and measured some - 14.1mm according to my "very nears".
I doubt you'll get as "slim" a washer as is sold in LBS at a hardware shop.
Cheers Al.
14.1mm is the inner diameter I assume? And by 'slim', do you mean the difference between the inner and outer diameter, or the thickness of the washer itself?
You don't happen to have any knocking around that you could let me have if I PayPal'd you some cash do you, prettypleasethankyouverymuchwithacherryontop... 🙂
yes, yes, no, sorry.
And sorry, I meant I'd measured a pedal thread, not a washer.
Ah, fair enough.
