In need of some new bearings, where is there a better place to buy from than CRC?
Hope ProII front bearings
FSA Pig Headset bearings
Pro II front are common as muck on ebay, lots of different types at all sorts of different quality. Last time i got some i got from Keasea's ebay shop.
Over the last year they have been faultless.
For the FSA Pig Headset bearings i am not sure where will be best for the loose bearings.
Look on the bearing for the number, google it and see what you get. They could well be available cheaper when not being sold by a bike brand.
UKbikestore's Hope bearing kits always seem pretty damned good value for a decent branded (INA) bearing.
I usually buy branded bearing from my local bear supplier, I would not buy cheap unbranded bearings.
how much is keaseas bearings?
i cant see ebay at work, all i have so far is £25 with CRC - with the advantage they have top and bottom bearings for the Pig.
Pro II front:
£16.34 from Kaesae's,
£15.90 from UKbikestore (stainless steel too)
both should be INA bearings (or FAG from K)
Both of these are approximately the same price as my LBS (local bearing supplier)
I was confused by this so had a look see.. I think that you looking at rear bearing kit on CRC for £25 (more bearings & different sizes)
now im confused as well.
the [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=24132 ]CRC Clicky[/url] has five bearings, is that not three for the rear and two for the front?
Nope you need all 5 for the rear hub (3 in the freehub & two in the actual hub) & there all different sizes to the front hub.
I only know cause I've been looking into bearing support tools...
