Boost with SRAM Eag...
[Closed] Boost with SRAM Eagle - issues?
[#9913188]
Just wondered if anyone else has had any issues running Eagle on bikes with Boost rear?
I’ve swapped from SRAM 1x11 to Eagle, but am finding that the chain is quite noisy in the larger cogs on the cassette- and the chain looks like its running at quite an acute angle when in the largest two cogs.
I’m running a non Boost chainring (which, according to manufacturer, should work fine), but I’m wondering whether a Boost chainring would help(?).  Only thing I can’t get my head around is that the Boost chainring looks like it would shift the ring outboard by 3mm - and, in my understanding, this’ll make the ‘crossing angle’ between chainring and 50t cog even more acute ........is that right?
Has anyone got any sensible suggestions that might improve the situation? (My old 1x11 has been used on another bike, and I don’t really want to swap back, as I’ve got used to that 50t bale out gear:)
p.s. I used the red plastic widget to set the derailleur up and it shifts a treat.  I got the lads at the LBS to check and tweak the gears, and it shifts even better, but the grinding noise is still there in the lower ratios.
Posted : 27/03/2018 9:51 am
Mine is fine, boost everything mind, and was specced as such by the manufacturer.
Posted : 27/03/2018 10:02 am
As above +1 (Scott Spark GX Eagle Boost OEM).
Posted : 27/03/2018 10:06 am
The Eagle is a world of hurt when its not running correctly and you only need the settings of just about anything to be off and it buggers it up.
Firstly, set your upper limit screw as normal so that the chain doesn't pop over the cassette. You'll actually notice that it doesn't get over the top and the jockey wheels don't line in with the 50t ring, they appear half way between the 50t and the next ring down and you can't get it any further. Just set it as high as possible I.E. when the line stops moving up with your turns of the screw.
Next, make sure you you use the red widget when the bike is at it's sag point and don't do it when the bike is in the stand, do it with the bike on the ground. Load yourself up with your normal kit, sit on the bike so the sag indicator slides back on your shock, then get off the bike and slowly let some the air out your shock until it drops to the indicator ring. Now use the red widget. This will ensure the mech has the correct spacing to the cassette when there is weight on it and the suspension is compressed. Pump your shock back up.
This should work fine but if after doing this you still get some grind, particularly when your on a steep climb, stand behind the bike with the chain in the 50t ring and back the b-screw off by just half a turn (moving the mech away from the cassette as this is what may have caused the grinding), at the same time you'll notice that the alignment of the mech also changes and it gets closer to the 50t.
What your doing is getting the balance between the maximum amount of b-screw and limit screw which in turn improves the chain line.
To answer your original question...personally I would run the boost ring with it too, if for nothing else than to rule out any other problems. I had a dodgy cassette to start with and had it replaced... but that's a whole other story !
Posted : 27/03/2018 1:14 pm
Only thing I can’t get my head around is that the Boost chainring looks like it would shift the ring outboard by 3mm – and, in my understanding, this’ll make the ‘crossing angle’ between chainring and 50t cog even more acute ……..is that right?
Boost chainrings shift the ring inboard, not outboard as you would think; usually by 3mm, with the aim of reducing that angle between the chainring and largest sprocket.
Posted : 27/03/2018 2:17 pm
Thanks for the replies and info., as it’s helped me decide to go for a Boost chainring.  My OH set the b screw with the widget whilst I was sitting on the bike.
I’ll try it with the Boost ‘ring and see how that goes, and then follow excitable1’s tips on adjusting the B screw if it’s still grinding on climbs.
Cheers fellas👍
Posted : 27/03/2018 3:03 pm
Non-boost chainrings move the chainring even further inboard.
Posted : 27/03/2018 3:08 pm
