Boost frame .....Bo...
[Closed] Boost frame .....Boost cranks?
 J273
[#9472453]
My new frame is boost. Do I need boost cranks or will my XTR m980's be ok set up single ring?
Ta
Posted : 02/08/2017 7:32 pm
Depends if you can achieve the correct chain line
Posted : 02/08/2017 7:39 pm
It's not about chain line. If you have tyre clearance and frame clearance, then your existing chainset will do and actually gives a better chain line.
Posted : 02/08/2017 7:44 pm
Try it. Might depend on your desired tyre width though.
As above, if it clears the frame & tyre go for it.
I've run my boost frame with single ring XT cranks and the ring was very close indeed to the chainstay, boost made it better
Posted : 02/08/2017 7:47 pm
 J273
Ok thanks guys. I'll try the cranks I have to see if I can make them work.
Frame hasn't arrived yet but hopefully these will do.
Posted : 02/08/2017 7:59 pm
Can only speak of Santa Cruz, as it's the only boost bike I've bought, none of them come with boost cranks.
Posted : 02/08/2017 9:14 pm
On my boost frame, I have to run boost cranks (ring actually) with a 32t oval. With a 30t round, I ran a conventional set up.
Posted : 03/08/2017 5:16 pm
32t single ring on m980 cranks in a boost frame here with no problems. As others have said it will depend on your frame.
Posted : 03/08/2017 7:48 pm
Doesn't it depend on the BB shell diameter? My boost frame runs standard 73mm but thought a boost BB was nearer 80mm?
Posted : 03/08/2017 9:26 pm
Nope. The BB/shell doesn't change for Boost.
Posted : 03/08/2017 11:16 pm
I have Boost cranks on my 73mm b/b Cotic SolarisMAX...
Posted : 04/08/2017 6:12 pm
You learn something new everyday. So I guess the big lad is for fat bikes?
Either way my boost frame has a standard chainset as far as I can tell.
Posted : 04/08/2017 8:06 pm
