I need to space out 142mm wheel to a Boost 148 frame.
Anybody know where I can get adaptors in the UK?
I've been looking at buying washers separately but it's a PITA finding the correct thickness and OD.
Have you tried 18bikes? They are the Lindarets importer.
What hub?
Superstar hub.
Cant see Boost adaptors on 18bikes site.
I'll mail and ask.
Is this not going to play havoc with your disc rotor/caliper spacing?
Aren't they designed to fit DT hubs?
Also worth mentioning that DT advise strongly against using them and that doing so will nuke any hub warranty you may have.
The Boost "Standard" is designed to work with DT hubs only? Really? If so how is that a standard?
Adaptors I've seen come with rotor spacers.
Not too worried about hub warranty.
Seen those. Pricey, and I'd still have to source rotor or caliper spacers.
If I don't get a reply from 18bikes I may have to import some or continue looking for washers as ghetto spacers.
Scroll down the page a little...
I think he means the spacers are for DT hubs.
You will need end caps specific to your hub so can't just get a DT kit to put it on a superstar hub, I doubt anyone other than superstar would make an adapter for their hubs
Ahh you mean the American ones...
Yes, those were what i was referring to when I said I might have to import some.
I think he means the spacers are for DT hubs.You will need end caps specific to your hub so can't just get a DT kit to put it on a superstar hub, I doubt anyone other than superstar would make an adapter for their hubs
Yes of course. If SS did Boost endcaps/axles I'd have just ordered some. The adaptors I'm looking for are simply 3mm washers for either side of the axle and a 3mm spacer for the rotor. They are manufactured just not easy to get from a supplier in the UK it would seem, hence the thread.
How about these from Stu's link?
£25 total, ish.
Yep, I may have to resort to those.
I'll see what reply I get from 18bikes first.
I have the dt version from Lindarets, great simple but of kit, got mine direct from the states with quick delivery.
Can't see how it makes the dt hub any weaker, people have been using centre lock to 6 bolt adapters for years, this is no different and Lindarets send you very high quality bolts in the package
Don't hope do an adapter kit for the Pro 2? probably wont help with the axle but the disc bit might be usable.
