Bontrager TLR valve...
[Closed] Bontrager TLR valve cores - how to remove?
[#934033]
I need to take the valve cores from the presta valves to get some more Super Juice in. How do I do it? I don't want to go all brutish with pliers & knacker them.
The tyres are mostly sealed, but went down overnight so I guess more gunk is required.
Posted : 08/10/2009 3:28 pm
Pliers.
Posted : 08/10/2009 3:30 pm
Do they screw out or just pull out?
Posted : 08/10/2009 3:31 pm
 Sam
They screw out. Unwind the portion below the valve itself (ie the threaded bit a valve cap would screw on to with flats on either side) from the valve stem.
Posted : 08/10/2009 3:47 pm
Thanks Sam. If I get it sorted tonight, the replacement Swift will get it's first ride this evening.
Posted : 08/10/2009 3:54 pm
screw
Posted : 08/10/2009 4:00 pm
LBS might have some Mavic little plastic 'clips' which are infact mini spanners for removing valve cores, they come free with UST Mavic rims.
Posted : 08/10/2009 4:02 pm
Not all valves have removable cores. If in doubt, just pop a section of bead off the rim and pour the juice in.
 Sam
Every tubeless valve I've ever seen has a removable core - and most definitely the Bonty ones do.
Posted : 08/10/2009 4:15 pm
[i]Every tubeless valve I've ever seen has a removable core [/i]
So that means they all do? Jeez, there's always someone who has to argue!
Posted : 08/10/2009 4:21 pm
I've got a spoke key that covers all different sizes and one of those is the perfect size.
But I prefer to pour the juice into the tyre after peeling a bit of bead off the rim. It saves risking breaking the rim seal.
Posted : 08/10/2009 4:29 pm
I found the things kept spinning round when I attached a threaded pump 🙁 Hope you've done em up tight!
For Sam:
Now you've seen one without.
Yes, I know its not a Bonty TLR one, but then seeing as TLR stand for tubeless ready, I doubt there is such a thing.
Posted : 08/10/2009 5:49 pm
thanks all. valve now in bits. haven't put any juice in yet - thought better of going on night ride on a new build. best have the shake-down ride in day light.
Posted : 08/10/2009 8:01 pm
 Sam
Fair enough - I stand corrected. I'd seen Shimano, Mavic, Stan's and Bontrager ones - all of which had removable cores. Kinda silly not to have a removable core really - helps a lot with getting enough volume of air in there to get the tyre seated.
Posted : 08/10/2009 9:48 pm
🙂 that's out of one of my old Crossmaxs
Posted : 08/10/2009 10:51 pm
 Sam
I guess they saw the error of their ways 😉
Posted : 08/10/2009 10:54 pm
