bontrager rhythm co...
[Closed] bontrager rhythm comp hub service
[#1071650]
why cant the conglomerate known as Trek stick these instructions up on their website?!
i've just bought a second hand set of these wheels and would like to convert the rear hub to a 10mm bolt-through if possible. been looking for service instructions to show me how to get inside the thing but can't find anything.
someone out there must know, or do all you Trekkies take your bikes to be serviced by at the shop?
Posted : 24/11/2009 10:50 pm
bumpy bump
Posted : 25/11/2009 11:57 am
Think you'll find it's either a DT or, if memory serves right, a Formula hub depending on which wheelset it's from. Give Trek UK a call, the guys in their warranty/service dept will fill you in on what they are.
Posted : 25/11/2009 3:04 pm
I've only ever had to [s]do[/s] fix things on the front one but the rear is probably a similar arrangement.the adapters for th qr are just a push fit albeit a tight one , then it's just like a cup and cone axle to remove the rest.
