Bontrager 15mm hub ...
[Closed] Bontrager 15mm hub conversion help
 H
[#3160124]
Evening,
I have a set of bontrager 29er wheels and I would like to convert the front wheel from a standard QR to 15mm. I have heard that some of the bontrager hubs are dt swiss hubs but I cant find any indication to confirm this.
My hub looks like this:
Both of the ends caps pull out and reveal a sealed bearing inside. Does anyone know if its possible to convert this to 15mm?
Thanks very much, H
Posted : 18/09/2011 7:37 pm
Will check on Trek's dealer system tomorrow to see if they list a conversion kit,otherwise, if they're 61804 bearings then Hopes 15mm kit may well fit as long as the hub widths are similar.
Posted : 18/09/2011 9:31 pm
