Bolts under downtub...
Bolts under downtube
[#12778201]
Seen a few bikes recently with bottle cage bolts under the downtube, much nearer the BB that the headtube so wouldn't have thought they're for a mudguard and seems a silly place for a bottle cage. Anyone know whqt these are for? Maybe some kind of bolt on frame protector?
Posted : 03/04/2023 4:53 pm
for this sort of thing:
https://www.wolftoothcomponents.com/products/b-rad-accessory-strap-and-mount
Posted : 03/04/2023 4:57 pm
kelvin reacted
I run a tool bottle in a cage on mine
Posted : 03/04/2023 4:59 pm
kelvin reacted
Even under the downtube facing the ground?
Posted : 03/04/2023 5:01 pm
Extra bottle position, believe it or not.
Quite common on gravel or adventure bikes.
Posted : 03/04/2023 5:05 pm
zerocool and kelvin reacted
It's an (American, mostly) bikepacker thing.
I don't get it either, your bottle will get manky but in a dry, dusty California, designers don't seem to comprehend that problem. To be fair, it's probably not that much worse than seatstay bottle mounts like I have on my rigid 29er and can be mitigated with a bit of planning on journeys.
Posted : 03/04/2023 5:08 pm
I have them on my tourer.
My msr fuel bottle lives there.
Posted : 03/04/2023 5:14 pm
kelvin reacted
sorry missed "downtube". thought it was odd you said near BB rather than near seattube, and that you'd think it could have been a mudguard mount!
Got one on my 2012 Peregrine, UK designed, not Californian. Never used it for exactly the same reasons as above. Always thought if I used it for water, it would be decanted into cleaner, inside-triangle bottle. Or I'd use it for tools.
Posted : 03/04/2023 5:18 pm
They have to be by the BB as the front wheel occupies a deceptive amount of the space available when bottomed out on an MTB (or on a drop bar bike with a short top tube).
You can fit a ~750ml Ti mug with all your cooking gear between the cranks. You could put a drinks bottle there, but it'd be largely inaccessible (your arms are nowhere near long enough, and the cranks/chainring are in the way), and you'd probably need to put a strap round it to stop it falling out, that'd just be if you had a long way to go between water sources and could swap bottles around.
Calling them a bottle mount is a misnomer really, they're not really any more a bottle mount than the ones on the top tube for a feed bag.
Posted : 03/04/2023 5:49 pm
I use the under down tube bottle mounts to carry water, useful when I have a full frame bag in the way of the other mounts.
It does get covered in whatever I ride so I decant it into the bottles I have on my forks or take the cap off before I drink out of it.
Posted : 03/04/2023 5:51 pm
Calling them a bottle mount is a misnomer really, they’re not really any more a bottle mount than the ones on the top tube for a feed bag.
Seen folks running bottles there too on big (dry) events.
Posted : 03/04/2023 5:53 pm
My 2009 Van Nicholas Amazon has them. It's nothing new on touring bikes. I've occasionally used mine for a 3rd water bottle if I've been doing long overnight rides as it's often difficult to obtain safe, clean water when it's pitch black.
I had brant fit a triple set to my custom Ti hardtail so that I could fit an Anything/Gorilla cage.
Posted : 03/04/2023 5:54 pm
If I'm doing a "big" ride, I'll stick a cage there with my tool keg in (and a strap to stop it pinging out) leaving me room for 2 bottles in the frame.
Posted : 03/04/2023 6:19 pm
I used to put my lumicycle battery in mine. Might start using one of those bottle tool caddies.
Posted : 03/04/2023 6:43 pm
Used to have them on my 1989 Cannondale beast of the east frame. But that didn't have a set on the seat tube, so they stuck the extras on the underside of the down tube.
I did use them occasionally, but it was a difficult place to grab a bottle from.
Posted : 03/04/2023 7:02 pm
Sometimes it's the only place to put bosses cos there was no room in the front triangle for a bottle and yeah they were for a bottle cage, things have improved with designers putting an ugly kink in the downtube to accommodate a bottle, I've used them for a pump and some of those fix-it sticks Allen key tools in the past, no way I'd put a cage on there.
Posted : 03/04/2023 10:46 pm
I get the use case for the mounts on a tourer, gravel, road, but not on a 'hardcore hardtail'.
My BfeMAX has 3 bottle mounts in the main triangle which are super useful, but also a set on the bottom of the DT.
I haven't seen them for months as they are always covered in mud. Would hate to mount anything there.
cotic
Posted : 04/04/2023 11:37 am
Enduro-ists seem to like a bolt on widget carrier as almost as much as bike packers.
My new bike only has one bottle cage mount and small front triangle space (it'll fit a 1l bottle, tube taped to the frame, and not much else) and it's annoying me because now my tool carrying options are either a clip on saddle bag that doesn't touch the seatpost. Or investing into one of these disproportionately expensive bar end/steerer/BB mounted spares/tools kits.
Posted : 04/04/2023 11:49 am
Yup, I'm one of those. I hate carrying things so strap them to the bike. I still have no use for 4 bottle mounts.
Posted : 04/04/2023 12:10 pm
Top tube bag @thisisnotaspoon? I've got one on my Bizango as it only has 1 set of bottle bosses and I fitted a dropper. Also got one on my Diverge.
LifeLine Adventure Top Tube Bag
Posted : 04/04/2023 1:02 pm
