Bolted thru axle ne...
[Closed] Bolted thru axle need help removing
[#10327482]
Do I just back this off with a 5 mm hex head (normal thread)? It's very tight and I'm worried I'm backing off the wrong part. I can't see any pinch bolts or anything,
Posted : 14/11/2018 5:22 am
Managed to back it off just think it was over torqued a bit from CRC
Strange cos the rear axle was barely tight.
Posted : 14/11/2018 5:47 am
Yep, one on mine have approx 10-16nM torque written by hex key hole, I usually go towards lower end so I can take wheel off easier on the road if the fairy visits.
Posted : 14/11/2018 9:59 am
