The rack mount at the top of the seat stay on my tricross is broken in some way - there's a bolt in there (no rack), and when I try to remove it the fitting is just turning with the bolt, the fitting's come loose some how. Anyone experienced this before?
I can drill the bolt out I guess. But is the mount bolexed, or is there a way of fixing this?
Posted : 02/04/2012 10:21 am
need to find a way of gripping the insert (rivnut) and loosening the bolt.
Posted : 02/04/2012 10:25 am
Once you get the bolt out a dab of superglue may fix the turning fitting.
Posted : 02/04/2012 10:50 am
Is it a rivnut? if so they can be tightened up
http://singletrackworld.com/forum/topic/help-tightening-a-rivet-nut-water-bottle-bit-in-frame
Posted : 02/04/2012 11:07 am
Posted : 02/04/2012 11:28 am
