Boingiest 30.9mm se...
[Closed] Boingiest 30.9mm seatpost?
 maxb
[#8084989]
Changing frame and going from a very nice flexy 27.2mm to a 30.9mm.
Has to have around 15 - 20mm setback. And be black.
Extension is around 9" to top.
The Easton EC90 setback seems to get quite a few recommendations as one of the most comfortable - anything else out there?
I know inline Thomsons are not very flexy but does the layback type have any comfort?
Posted : 01/10/2016 10:48 am
By a USE shokpost and pretend it's a dropper.
Posted : 01/10/2016 10:52 am
27.2 and a shim ?
Posted : 01/10/2016 10:56 am
 maxb
Definitely don't want a 'suspension' seatpost.
I've considered shimming a 27.2mm and this would be ideal...but...however many people say this has never been an issue with a reputable and long shim there are still enough un-explained cracked seat tube stories and manufacturers still refusing to sanction the use of shims with their frames that I don't want to take the risk, however small.
Posted : 01/10/2016 11:00 am
 Yak
Kcnc are quite flexible. Have a look on the Clee cycles website.
Posted : 01/10/2016 11:04 am
Canyon do two different VCLS posts, one normal one and the 'bladed' 2.0 which looks like two leaf springs. They used to sell them through their online shop but I can't find them now, but you could give them a ring and ask, it wasn't any more expensive than any other mid-high end carbon post, £110 IIRC.
I've got one of the original ones and even on a road bike it's noticeably more damped than the one it replaced.
Their trick is to use bassalt (igneous rock!) fibres in the carbon which have a higher hysteresis (damping) so they can make the posts flexible without the feeling of riding a spring (like a steel or titanium bike/seatpost). It's genuinely in a different league to other carbon posts.
Posted : 01/10/2016 11:46 am
I have been using a Syntace Hi-flex in 30.9 with good results.
It is on a alloy hardtail and the bike isn't overly harsh.
The tubeless tyres may help but I thought the ride may be a bit bone jarring but it surprisingly is not.
Quite pricey though!
Max
Posted : 01/10/2016 12:30 pm
