Bodging a workstand...
[Closed] Bodging a workstand mount...thoughts appreciated.
[#6456094]
I've been trying to get my new [url= http://www.chainreactioncycles.com/tacx-t3350-spider-team-workstand/rp-prod121124 ]Tacx Spider Team[/url] workstand to work with the 15mm QR on my Fox 32 CTDs.
The provided mount isn't the right shape - even though Tacx say it's designed for 15mm axels. See below for the particular problem:
Currently the fork won't go all the way over the mounts, since they don't have the corresponding cut-out.
I've contacted Tacx directly, and their response was pretty much "there's nothing we can do".
SO. Time for a bit of tinkering. I'm fairly sure all it needs is some excess plastic taken off. What do we reckon...use a file?
Potential problems are that the mounts themselves have [url= http://imgur.com/opFvmVV ]quite a narrow lip[/url] and have a [url= http://imgur.com/N1LgLbA ]bevel on the edge[/url].
Posted : 02/09/2014 7:03 pm
I'd just file it until it fitted.
Posted : 02/09/2014 7:12 pm
It's not clear to me where that adaptor fits.
Posted : 02/09/2014 7:15 pm
It pushes through the axle hole in the fork so it fits in the stand clamp.
Posted : 02/09/2014 7:22 pm
And then use a standard QR?
Posted : 02/09/2014 7:23 pm
[url= ]This might explain it best[/url]
It uses the Fox QR15.
The mounts fit inside the slider thingy on the workstand. Forks go over mounts, QR15 slides through as it would through a wheel.
Posted : 02/09/2014 8:11 pm
That makes more sense.
IMO Easiest/neatest option would be to cut the lip on the adaptor down to the same diameter as the hub seats on the forks.
Posted : 02/09/2014 9:08 pm
