Bodgers - 29er Rock...
[Closed] Bodgers - 29er RockShox Lower removal
[#5525359]
Doing an oil change on a set of 29er SIDs for a mate, don't have a long 10mm socket to hand - anyone managed to remove the nut on the non drive side using anything else? The one that's recessed an inch or two up inside the lowers?
Posted : 17/09/2013 5:44 pm
 LoCo
Deep 10 mm socket on end of extension bar is only proper way really if you don't want to damage anything ( on the plus side you get to buy new tools 😉 )
Posted : 17/09/2013 5:51 pm
Yeah, figured as much. Was trying to reach it with a wee spanner, but acutely aware of the alloy-ness of the bolt and didn't want to round anything. A carefully bent ring spanner might work, but I don't have one of those to hand either (or the strength to bend it)
Socket purchase it is, I guess.
It's kind of a neat design, thinking about it. Means the major parts are all the same, just the change in lowers.
Posted : 17/09/2013 5:56 pm
My deep sockets weren't deep enough!
It was late at night - so after much cursing I ended up taking a cheap old 10mm socket, drilling out the 1/4" square drive, filing off the chrome plating, finding a bit of tube sort of the right diameter, squashing tube until it sort of gripped the outside of the socket, attacking that mess with a blowlamp and silver solder to make a ghetto long socket. Drilled a cross hole at the other end of the tube to shove in an allen key as a tommy bar.
Then proceeded to get the damper oil all down my trouser leg rather than in the bucket!
Grrrrrrr!
Posted : 17/09/2013 6:51 pm
10mm box spanners are cheap as chips 😛
Posted : 18/09/2013 11:28 am
Yep as above - I got a box spanner from the local hardware shop for a couple of quid
Perfect
Posted : 18/09/2013 11:42 am
 LoCo
Forgot to mention, use 6 sided socket to reduce the chance of damaging the nut when you tap it to release the studs from the lower legs. 😀
Posted : 18/09/2013 12:21 pm
