Blue Fox Fluid ques...
[Closed] Blue Fox Fluid question...
[#5411731]
Fox 32 RL 100mm fork rebuild question
Is the blue Fox Fluid for the foam rings and lube duty only or is this the stuff that actually goes in the fork ?
If it is, great, if not, whats the recommended stuff..
Thanks
Posted : 11/08/2013 11:34 am
Float Fluid is the thick gloopy blue stuff (think it's 80 wt gear oil with blue food colouring), then special* Fox oil comes in different colours. You'll probably want "green".
http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm
In fact, I don't think you need the Float fluid at all if you're doing a seal change since Fox now recommend you soak the foam rings in the fork oil, which is what everyone was doing anyway.
* I say "special" but I think we're back down the food colouring route
Posted : 11/08/2013 11:54 am
yeah the float fluid only goes in the air chamber if you have tripeed that down. otherwise soak the foam rings in the green fork oil (if you're using fox oils). as flaperon says. 🙂
Posted : 11/08/2013 11:57 am
what flaperon says, Fox finally realised that the fork oil flushes the thicker float fluid out of the rings so it's redundant.
Perfecto, thanks..
Posted : 11/08/2013 12:06 pm
