I always thought this was a sort of metaphorical expression for sexual frustration ... until I had a Testicle-Stem 'incident' after a track stand went wrong in the wet. Now I genuinely have dark blue balls 😯
I wonder if I should see a doctor? ❓
No pics I'm afraid
if they continue to swell or serious pain continues then yes. go to A&E
No pain, just looks like I have leprosy of the bollocks! Impact site was behind the nut sack (perineum?) But looks like a load of blood took a wrong turn 😆
I'd be tempted to do as TJ says anyway.
Bruses in the sack always look spectacular. The real danger is busting ' twisting a bollck IIRC which is very painful. No swelling / numbness/ / not excessively painful it should be fine - bearing in mind that [s]without pictures[/s] over the internet diagnosis is impossible
[b]without pictures[/b].TandemJeremy - Member
...bearing in mind that without pictures over the internet diagnosis is impossible
Fixed it for you, but I'm not coming back to this thread just in case pics appear 🙂
[url= http://blueballfixed.ytmnd.com/ ]Blue balls[/url] (Safe for work)
You've done the right thing by asking here first. STW should always be your first port of call when it comes to anything medical, legal or pertaining to mental health issues.
If you can get a referral, then and only then should you approach a qualified professional. You can sift out less helpful answers by using the 'I'm not...' rule.
For example: 'I'm not a nuclear scientist, but I seem to remember reading somewhere that nuclear fission can potentially be harmful to household pets, so if in doubt, lock them in the airing cupboard until the mushroom cloud has completely cleared'.
Since none of the replies here begin with the crucial phrase: 'I'm not a doctor..' I'd take them with a pinch of salt, since there's always a danger that they may have some idea what they're talking about.
You can also exempt TJ from this rule, since he is one of several STWers who is never wrong.
HTH.
I would really start to worry if they turn square and start festering at each corner. 🙁
[url= http://en.wikipedia.org/wiki/Blue_balls ]Blue Balls[/url] Also safe for work. 😉
