blocked grub screw ...
[Closed] blocked grub screw on rebound adjuster - Help!
[#7901954]
When trying to replace the oil on my forks I've managed (god knows how) to snap the end of the 1.5mm allen key off in the grub screw on the rebound adjuster - this means I can't get the grub screw off.
Any ideas on how to sort this out? Am I going to hell?
I've tried magnets, tapping it, banging it, hitting it, using a pin, using a needle, pushing it in as far as possible to use the allen key... next option is drilling it out 😕
Posted : 21/06/2016 8:48 pm
[u]Trying[/u] to drill it out may be all that's needed. Assuming you were trying to turn it anticlockwise when it broke, and it's jammed in because it's rotated in the socket, the clockwise torque of the drill may free it. Drip some oil in first and drill gently, to avoid jamming it the other way.
Posted : 21/06/2016 9:42 pm
Superglue on another allen key and carefully pull the broken bit out?
Posted : 21/06/2016 9:56 pm
Interesting idea, I was thinking if I cn get the adjuster off I can order a new one and still use the fork
Posted : 21/06/2016 10:00 pm
Ashy - I did think of that but worried about the risk of supergluing the Allen key to the rebound adjuster 😯
Posted : 21/06/2016 10:01 pm
Is it acetone that dissolves superglue? Nothing lost in that case. Maybe a totally daft idea but try hoovering it out whilst poking it?
Posted : 21/06/2016 10:10 pm
Good point on both points 🙂
Posted : 21/06/2016 10:13 pm
Tried the superglue and no joy. Then tried drilling it out and I think the allen key piece is hardened as the drill is just spinning and having no effect 🙁
Gutted.
Posted : 22/06/2016 11:58 am
If you are planning on replacing the adjuster, use a fine tooth junior hacksaw to cut a slot through the adjuster and grubscrew and use a screwdriver. (would be my next plan of attack, not promising it'll work).
Posted : 22/06/2016 12:55 pm
Bluetack?
Posted : 22/06/2016 1:43 pm
Small drill bit in reverse. You'll only need to just snag some of the Allen key/grub screw assembly and the whole thing will come out. Possibly quite quickly.
Posted : 22/06/2016 3:01 pm
Will give that a go. Depressed at how few options left other than ordering a new rebound damper at £140 a go!!!
Posted : 22/06/2016 3:51 pm
OP - can you not just sacrifice the rebound adjuster?? Thinking along the lines of carefully hacksaw one side and prise open?
What fork is it and have you any pics
Posted : 22/06/2016 4:00 pm
Not sure, it's a bit tight in there...
The forks are a pair of Marzocchi 350 NCR
[Grumble]Stupid 1.5mm hex grub screw!!![/grumble]
Posted : 22/06/2016 4:15 pm
You weren't using a ball end in there were you?
Posted : 22/06/2016 4:26 pm
yeah, wasn't thinking. It was one of those "Doh!" Homer Simpson moments you have in life that you instantly regret.
Posted : 22/06/2016 4:33 pm
araldite a second allen key in?
Posted : 22/06/2016 4:36 pm
Hmmm, swap out the hacksaw for a Dremmel?
Is araldite the same as superglue? If so I did it this morning...
Posted : 22/06/2016 4:43 pm
I've got a Dremel - any suggestions on what bit to use? cutting wheel or diamond tip drill or another?
Posted : 22/06/2016 4:45 pm
