Bleeding Tecktro Au...
[Closed] Bleeding Tecktro Aurigo comp disc brakes - tips?
[#1277594]
Di need the dedicated kit or can i do it shimano style with a bit of pipe?
Posted : 31/01/2010 1:08 pm
I have a set, which I haven't had to bleed yet, but IMO looks lust same as a Deore to bleed
Posted : 31/01/2010 1:14 pm
i do mine in the same style as shimano, syringe and tubing from caliper end pushing oil upwards
Posted : 31/01/2010 1:30 pm
Yup, no need for the kit. But, they do have a habit of having the diaphragm not deflate, which means you end up with very little fluid in the reservoir, so I do mine by taking the rear cap off rather than trying to use the bleed hole, it's a bit of a faff but it works better. Careful of the tiny bolts if you do this!
Posted : 31/01/2010 1:47 pm
