Bleeding technique ...
[Closed] Bleeding technique for shimano brake after fitting new hoses?
[#7260368]
New longer hoses needed on my new build. The calliper and lever will have oil in them (last gen xtr trail brakes btw), so do I just fit the cup and pump oil down and the air will bubble up, or should it fill with a syringe from the bottom up?
Posted : 12/08/2015 7:20 am
syringe from the bottom up. Use the funnel to collect the excess.
Posted : 12/08/2015 7:22 am
 jn49
As above.
Posted : 12/08/2015 7:32 am
Cheers.
Posted : 12/08/2015 7:35 am
Recent thread here might help:
http://singletrackworld.com/forum/topic/shortening-shimano-brake-hoses
Posted : 12/08/2015 10:56 am
Those 2 suggestions definitely work well for a simple bleed on an existing system. I've used this technique many times.
I used the bottom up method to purge the old oil from the calliper, air from the new hose and remaining oil in the reservoir / lever. This worked very well. I had no air bubbles after pushing enough oil through to fill the cup. The levers felt good straight away.
I'm actually amazed how mucky the old used oil looked.
Posted : 13/08/2015 10:52 am
