Bleed kit for SRAM ...
[Closed] Bleed kit for SRAM RSC brakes?
[#8037006]
Am I right in thinking the standard SRAM/Avid offering isn't up to much?
Posted : 05/09/2016 3:52 pm
Sram Pro kit is a lot nicer
Posted : 05/09/2016 4:26 pm
Reverb syringes work well
Posted : 05/09/2016 8:01 pm
I was too tight to buy the pro kit so bought the Epic one which has been fine so far.
Posted : 05/09/2016 8:44 pm
 nuke
Another vote for Epic kit...good fast comms too from Alex when i emailed with a query
Posted : 05/09/2016 8:46 pm
If it's the new version (with the S4 caliper) you will need the SRAM Bleeding Edge connector for the caliper end.
Posted : 05/09/2016 8:57 pm
benpinnick - Member
Bloody awful for bleeding Reverbs though. They leak!
Got two sets and all four syringes leak out of the hose ends. That's with the Reverb fluid (2.5wt stuff).
Old Avid kid for bleeding Avid dot 5.1 stuff and never had a problem with that.
Is it the syringes or the different oil with the Reverb that makes it more likely to leak out the ends? (thinner oil than dot stuff?)
Got syringes that came from TF Tuned also for doing fork lowers, but those are rubbish too. The rubber bit inside got swollen, stuck and ended up pulling it right out and now it won't go back in. Didn't use it for brakes, just for the forks.
Posted : 05/09/2016 9:41 pm
Another vote for epic bleed kits. I was too tight to buy the sram one and epic wad £15 including fluid. Only thing missing was a brake bleed block. I had a perfect size set of pliers that fitted through the caliper exactly right.
Brakes were dragging horribly before bleeding, but now feel perfect.
Had an epic kit for my magura hs33s too and that did the job well.
Posted : 06/09/2016 8:34 am
Question: I bled mine just before.... well when I met up with Ben at Hamsterley... I followed some video guide - might have been from BikeRadar...
Anyway, they were a bit TOO bled, after I'd finished - I only have the RS so no contact point adjustment. New pads too, but there's only a tiny bit of movement before they bite, which I can cope with but I'd preferred about another 5mm of lever movement before any action happened.
I've not touched them since because they're a pain in the hoop to bleed... but what could I have done different? I messed up the first time as I didn't pressurise the system from the lever end the first time... maybe I did too much there?
Posted : 06/09/2016 8:50 am
