bled brakes - no mo...
[Closed] bled brakes - no modulation..
[#9686437]
Hi folks. Bled my sram rsc brakes today and there's no modulation in the lever, seems as if there's too much fluid in the system (is this possible)?
Posted : 24/11/2017 8:52 pm
Yes, it is possible to get too much fluid if the pistons were not fully pushed in and resting on a solid of sorts during the bleeding.
Posted : 24/11/2017 10:14 pm
Have you would out the pad contact adjust? Your pads are just slammed against the rotor.
If that doesn't work, reset the pistons and realign the calipers.
Posted : 25/11/2017 1:31 am
Sticking master piston.Seen loads (about 20 sets at Mayhem).
Posted : 25/11/2017 8:48 am
Used a bleed block between pistons and the pistons were replaced as well so not seized. The brakes work fine but there either on or off..
Posted : 25/11/2017 10:52 am
 poah
how much lever pull do you have?
Posted : 25/11/2017 12:22 pm
Loads of lever pull..its biting almost instantly.
Posted : 25/11/2017 5:54 pm
