bled brakes - no mo...
[Closed] bled brakes - no modulation..
[#9686444]
Hi folks. Bled my sram rsc brakes today and there's no modulation in the lever, seems as if there's too much fluid in the system (is this possible)?
Posted : 24/11/2017 8:53 pm
Did you bleed with pistons pushed all the way in? If not, squeeze a bit of fluid out.
Posted : 24/11/2017 9:29 pm
I had a bleed block in.. Shall I just open the bleed screw on the lever?
Posted : 24/11/2017 9:38 pm
Nope, caliper end to get rid of some oil
Posted : 24/11/2017 9:44 pm
OK.. many thanks.
Posted : 24/11/2017 9:47 pm
