Bit of help needed ...
[Closed] Bit of help needed - headset cartridge bearings.
[#3068273]
I need to replace the cartridge bearings in my headset as its started leaking brown crud and feels a bit notchy.
The bike is a 2010 stumpjumper fsr but I cant seem to find a definitive answer as to what bearings are needed. The spec sheet describes the headset as:
campy style cartridge bearings for integrated alloy head tube.
The headset has cane creek written on it.
Cane creek's website reckons I need:
SHIS:IS42/28.6|IS42/30 (1-1/8" Italian Integrated IS Standard)
which doesn't mean a lot to me to be honest.
I've found these on crc which look like the correct ones but I cant be sure.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11266 ]these[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11267 ]and these[/url]
Could someone point me in the right direction, either to replacement bearings or full headset. I've tried to get my head round all the different standards but its all a bit too much.
Posted : 20/08/2011 7:42 pm
Neither of those...
Posted : 20/08/2011 7:47 pm
Ok thanks, saves me buying them. Do you have any other suggestions? Anyone?
DO I need a headset/bearing specific to the frame or will any 1 1/8 integrated headset do the job?
Posted : 20/08/2011 8:23 pm
Shameless bump. Does anyone have any suggestions?
Posted : 21/08/2011 6:33 pm
If you measure them, would an online bearing supplier (e.g. simplybearings.co.uk) be of any use?
Posted : 21/08/2011 6:38 pm
Or your Specialized dealer?
Posted : 21/08/2011 6:49 pm
This is what you need - 45 x 45 bearings (as opposed to most 'normal' ones which are 45 x 36).
http://www.chainreactioncycles.com/Models.aspx?ModelID=38690
Posted : 21/08/2011 6:52 pm
That looks promising, thank you. Can I ask how you know that it needs 45 x 45? Google has let me down for once.
Posted : 21/08/2011 6:55 pm
I worked as the manager of a bike shop for several years. It's the Italian Integrated bit that gave it away. If you look for Campagnolo (or Campy) fit headset bearings you won't go far wrong.
Posted : 21/08/2011 7:18 pm
Same problem here! Camber Comp 2011 and the bike shop sold me a set of Cane Creek bearings as shown in the Chain Reaction link. They almost fit, but not quite.
So Campy means Campagnola?
Posted : 09/05/2012 11:56 pm
This is what my headset looks like: http://www.evanscycles.com/products/fsa/orbit-ce-integrated-1-1-8-inch-headset-ec007331
Posted : 09/05/2012 11:58 pm
Hi mate. I just replaced the headset on my 2010rockhopper it has exactly the same hs as yours. It was labelled up as a fsr headset.
Ring don skene in Cardiff they are a spesh dealer .... Just use google to find number. They will now know what your talking about.
( they are 45 x 45 but the outer diameter is different / the chamfered edge is different. It was a pain in the bum )
Hope this helps. Whatever happens post back with ur findings.
Posted : 10/05/2012 12:08 am
