Bird Have Done it A...
[Closed] Bird Have Done it Again!
[#8160735]
This is the reason I went for a Bird.
Fired them a quick message at the end of lunch today asking about my lower pivot bearings.
Got a reply saying they'll pop them in the post, no fuss! An example of how companies should treat customers.
Now.... What tool do I need to remove the old ones and fit the new ones? Never done bearings before 🙂
Posted : 14/11/2016 8:19 pm
 Alex
I did all mine a couple of months back. I think - but i can't be sure - you'll need a bearing puller/slide hammer for the lower pivots as they won't just knock out. Definitely the case on the swingarm set.
Give Bird a call, they'll talk you through it...
Posted : 14/11/2016 8:27 pm
Ah cool, how big of a job was it Alex?
I think I'll be capable of doing it, just need to buy the correct tools really.
Posted : 14/11/2016 8:39 pm
 Alex
Two of us - one who is very good with tools and me who is a mechanical savage - did all 12 or 14 or whatever i was in about 2 hours and we were taking care (plus we mixed the bearings up and a few are different, oh how we laughed...) so just the pivot ones probably 20 mins if you have the tools.
Basically remove bearing cap, pull bearing out, give the housing a wipe, tap new bearing in. Oh if it's the lower, I missed 'remove cranks' first!
Posted : 14/11/2016 8:43 pm
Yes, removing the crank will probably help 🙂
Suitable sized socket and rubber mallet to tap in?
Posted : 14/11/2016 9:45 pm
Bird continue to impress.
Thumbs up to the team there.
Posted : 14/11/2016 10:11 pm
 Alex
Yep. Interference fit. No Drama. Assuming you can hit the socket square 😉
EDIT: I'm racking my brains now if the lower pivot has an axle in there or something. Should have had a look when I was in the shed a minute ago. Nope, can't remember. It was all pretty obvious tho!
Posted : 14/11/2016 10:59 pm
Not so sure about hitting stuff square so I'd better have a practice 🙂
Just got a bearing extractor/press from Superstar for £7.50 for the 6000 bearing. That might help.
Posted : 14/11/2016 11:07 pm
