Biopace chainrings ...
[Closed] Biopace chainrings in Rotor position
[#4331366]
What do You think about use the old biopace rings as the Rotors? I mean, bolt up in other position.
Turn clockwise or ccw 1 or 2 hole(s). So...?
Posted : 04/09/2012 7:47 pm
You can emulate it to an extent but not truly because of the bolt pattern.
Posted : 04/09/2012 7:53 pm
Yeah, sure. The 5-arm crankset won't be ideal... but maybe it worth to try! 🙂 Should i turn 1 hole ccw?
Posted : 04/09/2012 8:04 pm
What the hell?
Posted : 04/09/2012 8:06 pm
Biopace tried to even out the pedal stroke by over gearing the dead spot. Rotors and q rings do the opposite by over gearing the power stroke bit. So 180 deg works best...which you can't do with a 5 bolt chainring. I've done it BTW and didn't notice any difference at all YMMV.
Posted : 04/09/2012 8:48 pm
I can turn the Biopace rings 144 or 216deg. Which one should I try?
Posted : 04/09/2012 8:57 pm
This was how I set them up.
I'd try both, like I say I never noticed a difference so I'm not exactly qualified to suggest one over the other. I was running singlespeed as well if it makes any odds.
Posted : 04/09/2012 9:07 pm
you want the most eccentric bit (biggest bit) of the ring top to bottom with the driveside crank in the 4 O'clock position or as near as you can to emulate positon 2 of a rotor Q ring/
Posted : 04/09/2012 9:08 pm
