Bike stands and mod...
[Closed] Bike stands and modern frames?
[#10796399]
How do people clamp their bikes when working on them? My old P7 is simple, clamp it at the seat tube and can rotate it 360 degrees. Whyte is a PITA though, there isn't a straight tube on it, clamping the dropper seems a bad idea, so it usually ends up upside down on the floor. Not v. helpful if I'm dropped the forks out
Posted : 04/09/2019 12:06 pm
Clamp the dropper. It can stand your weight on it, bouncing up and down and landing on it. Just make sure the clamp is clean and maybe put a soft cloth in it.
Also helps if you let the front wheel hang down as there is less twisting pressure.
Posted : 04/09/2019 12:18 pm
+1 for lightly clamping the dropper, when extended, with a cloth in the jaws
Posted : 04/09/2019 12:22 pm
It's more the pulling up on a dropper rather than the weight, thought that was a bad idea, especially with Reverbs? Results in squish?
Posted : 04/09/2019 12:37 pm
I'm sure it's fine, but I'm also a bit picky about clamping on my dropper. I just open the seat clamp and slide it out of the frame, and clamp on the main body of it.
Posted : 04/09/2019 12:38 pm
Do as bike shops are doing... Pull out your dropper and have non-dropper inserted for maintenance purpose only.
Simple as that 🙂
Cheers!
I.
Posted : 04/09/2019 12:54 pm
Always clamp the main part of the dropper post (just extend it out of the frame 20mm so the clamp fits) but not the shaft
Posted : 04/09/2019 12:57 pm
@twrch and @carlos good point. The Whyte has zero of the fixed bit of the dropper exposed - I could just extend it and clamp on that 🙂
Posted : 04/09/2019 12:59 pm
Do as bike shops are doing… Pull out your dropper and have non-dropper inserted for maintenance purpose only.
If you want to believe that, I'll not disappoint you. 😊
Posted : 04/09/2019 1:01 pm
