bike sizing, road b...
[Closed] bike sizing, road bike
[#1634035]
Can anyone point me in the direction of a good frame-sizing calculator. I'm a good 6'1", long in the leg. I'm looking at a new Basso Astra and want to get the sizing spot-on. Had a test ride on a 54cm today and it was obviously too small, especially when out of the saddle. But, mon dieu, quelle velo!!
Posted : 22/05/2010 11:02 pm
all sizing across the different manufacturers differs slightly so you may need get a try on one some how, but this one's pretty good.
http://www.competitivecyclist.com/za/CCY?PAGE=FIT_CALCULATOR_INTRO
I'm 6ft 1, 32 inch legs and monkey arms and I ride a large Giant Defy with a 110mm stem. Pretty irrelavant though to be honest.
Posted : 23/05/2010 9:24 am
You need to try lots out but you are probably looking in the 58/60cm range of sizes
Posted : 23/05/2010 9:27 am
Surely the bike shop you are buying it from should help you get the right size?
Posted : 23/05/2010 9:31 am
try them for reach and make sure there's at least 1 1/2" gap when stood over the top tube.
Posted : 23/05/2010 9:44 am
I'm 6'2" and ride roadbikes with 57ish toptubes.. and just to confuse that a bit, i've ridden bikes from 56 to 63 and they all felt right.
Only one true way to tell is to ride one.
Posted : 23/05/2010 9:45 am
I'm a smidgen over 6ft and 58cm frames are a good fit for me generally. You can change the reach easily with stems too. The difference of 10mm in stem length makes a masssive difference on my road bikes I find.
so 58 to 60cm is definitely the ball park area you should be looking at.
Posted : 23/05/2010 10:03 am
