Bike service casual...
[Closed] Bike service casualty list
[#5126321]
Ok, thought it was about time I serviced my hardtail (bike I ride most) as after the winter we've just had I knoew there were probably a few jobs needed, transmission a bit worn, little did I realise!
End results:
fork serviced (TF)
New chainring
New chain
New cassette
New pedals (flats worn beyond repair)
New BB
New grips (worn right through)
I can't believe I was riding the bike! Anyone else opened a similar can of worms when spring cleaning their bikes or is it just me?!
Posted : 03/05/2013 2:57 pm
Yep
New Chain
New Cassette
New BB
Fork Serviced
New Jocky Wheels
New Cables
New Rear Tyre
New Headset
Rear hub rebuilt
OUch
Posted : 03/05/2013 3:06 pm
Me too.
'Pig:
Chain, Chainset, BB, Bleed brake, Full fork home service, Cassette and roast brake pads in gas cooker to remove oil. Tyres too. Seat.
Yesterday: Seatclamp [broke on the way home, boo.
Thorn
Chain, Gearcables, Chinring, Rohloff Sprocket, Rohloff Oilchange, grips, seat. Front hub internals and grease. CKing service [at home].
Centrum
>8speed [Alfine/spokes/rim], shifter, Chain, rebuild front hub, Headset rebuild, dropout...
Maybe I should have done these jobs in the last few months!
Posted : 03/05/2013 3:10 pm
Glad it's not just me then. Think I got off lightly, should've ridden more over the winter!
Posted : 03/05/2013 3:35 pm
my roadrat
needed a new gear cable it seemed
found a broken spoke
Brown gunge in cables
chain thick with dirt and old oil
brakes needing new pads
serviced the alfine
Serviced the front hub
serviced the headset
new inners and outers
still out of action yet,
Posted : 03/05/2013 3:36 pm
yo, trail-rat
how do you service your alfine?
Posted : 03/05/2013 3:55 pm
yo, trail-rat
opened, looked in, looks fine, closed it.
Posted : 03/05/2013 4:09 pm
gofasterstripes, please can I ask about "roast brake pads in gas cooker to remove oil"???
Do you stick the brake pads in the oven? Does that actually remove oil? How's the oil got into them? My friend got some oil on his pads and it seemed like the pads and rotor were a write-off.
Posted : 03/05/2013 4:15 pm
Magura 6.1 pads seem to be pretty resilient.
Having bled my brake I was a little ham-fisted and splashed oil from the top syringe around, some got onto the pads.
Rotor was washed in HOT water and washing-up liquid, scrubbed with a brush to get inside all the cutouts etc.
Pads - I heated [with a wire through the retaining hole]them in a gas-ring flame until they were about 100C [spit test] and then heated them for about as long again [I assumed 200 or so was withing their capability - they are designed to insulate heat from the oil system according to Magura]. Quite a lot of smoke came off. I repeated this twice, allowing them to cool in between.
When they were cool I washed them in running water and rubbed the friction material of them together quite hard to remove any surface glaze.
I cleaned the inside of the caliper with cotton-buds and a little nail-polish remover.
I tested after in free space in case the pad was about to disintegrate. They way I see it you are supposed to buy new pads, I was resigned to doing-so, so I though I have nothing to loose.
The result was a success - braking restored. It may not work with DOT fluid, or with fancy Teflon fluid spills, but plain oil seems to come out.
I have also heard it suggested that boiling them in very detergent-y water for hours?days? might work.
Good luck.
Posted : 03/05/2013 4:26 pm
LOL
Also - different username?!
Posted : 03/05/2013 4:27 pm
Thorn
Mines nearly 7 years old and I'm still on the original cables. My third chain and sprocket went on at Christmas and my second chainring.
Posted : 03/05/2013 4:35 pm
I fix stuff as I go so I don't really have to do services as such but after the dudes enduro last year was a brutal one for the Hemlock... It'd just had its forks and shock done, so no worries there, but- new chain, mech, bottom bracket, rear wheel, back tyre, cables, service dropper post 🙁 Could have bought a car for that!
Posted : 03/05/2013 4:47 pm
Aye right!!! 😯
No he showed me the pics..
love
TR 😉
Posted : 03/05/2013 6:14 pm
I go ride my bike for 2 hrs and get accused of dual usernames.
Nope i can confirm bruneep is older wiser and has less hair than i
Posted : 03/05/2013 7:02 pm
Stepdad took his in for a service....
New, full, groupset. Chainset, cassette, chain, both mechs, shifters and cables.
Fox Upper CSU
Bearings (trek fuel ex 8.)
True both wheels.
Brakes needed bleeding and the seals replacing too but he just replaced them.
£800 later he keeps more of an eye on what needs doing and when....
Posted : 03/05/2013 7:21 pm
