Bike rack on a Pors...
[Closed] Bike rack on a Porsche Boxter
[#6933810]
Anyone know if you can fit a standard bike rack on a boxer. I'm planning very occasional use, probably a one bike the Saris Bones solo
ta
Posted : 15/03/2015 5:08 pm
Bones solo looks like it's meant for steeper hatches etc.
Posted : 15/03/2015 5:16 pm
Seasucker might also work...
Posted : 15/03/2015 5:41 pm
I'm no expert but why would you want to attach a bike rack to a boxer?
Be it a dog or a human.
Posted : 15/03/2015 6:07 pm
Saris Bones fits fine.
Posted : 15/03/2015 6:12 pm
Assuming that you mean a porsche boxster 🙂 then I had a boxster a while ago and when I looking into putting a boot mounted rack on the back posche don't recommend it because it's not designed to hold that type of weight.
You might get away with it, I never tried it.. you do get a roof rack for the boxster though.. but they're very expensive.
Posted : 15/03/2015 6:21 pm
Bike bouy...just tried one from the LBS which appeared to fit. Only issue was the straps which attach under the reg, as there wasn't a particularly sturdy bit of metal to attach it to. Do you have a boxter...and if so is it fine to attach the lower straps given they aren't weight bearing.
Posted : 15/03/2015 6:22 pm
tpbiker - Member
They are when you go over bumps etc, and can let go if not tight enough..
Posted : 15/03/2015 6:37 pm
No I don't have a Boxster but a mate has a 59 redg S' and he uses a Saris Bones 2 but only one bike on it. The lower straps go underneath the rear valance and the top two go in the grove behind the hood (there's a seal there and he just pushes the metal clamps in) he's got some soft cloth duct taped to the lower straps where it touches the bumper/boot so it doesn't scratch and uses the side clamps either side of the boot lid. Ive only ever seen the car parked but even with the rear spoiler "up" there's enough room as he's set the rack up quite high. It does foul the number plate but he's not bothered about that.
That any use?
Can you not try one for a Saris Bones dealer ?
Or in his case he bought it from Evans Cycles who offer a full refund policy if it doesn't fit etc..
Edit.. He takes the wheels off and sticks them in the passenger seat too, so it's just the frame on the rack.
Posted : 15/03/2015 6:54 pm
Thanks bikebouy
The one I have to try appears to fit ok and is only for use with my road bike so I hope won't be an issue. Does he just clip it anywhere under the valance, or is there a a prefered bit to hook it onto? My only isssue is the rear skiert deoesn't appear very robust, can't tell if its made of metal or fibreglass.
Posted : 15/03/2015 7:08 pm
 gg14
Boxster. Your car is a Boxster.
Posted : 15/03/2015 7:34 pm
Mate of mine has a 60 plate one with a thule roof mounted carrier on
Posted : 15/03/2015 8:23 pm
Hehe!
Posted : 15/03/2015 9:25 pm
Porsche do their own you know...
Posted : 15/03/2015 9:31 pm
