Bike Jerseys and Ja...
[Closed] Bike Jerseys and Jackets for mtbs - Useless?
[#6121876]
Am I the only one who finds most bike specific jackets and jerseys useless for mtb riding because of their rear pockets and nothing on the front?
If I'm out for the day I am more than likely to have a backpack and the rear pockets are not accessible, or if the pockets have something in them interfere with the backpack.
End result? I simply buy normal outdoor gear, but that doesn't have some of the useful things the bike gear has like drop rear, longer arms, a neater fit, and a collar that closes more closely.
Posted : 17/04/2014 8:17 am
The pockets are useless once you have a backpack on, but they don't make them usless.
I don't understand why they would, just don't put anything in them.
Posted : 17/04/2014 8:21 am
I agree (though can see the argument that items should be in your bag)
Also shorts with non zipped pockets?! Yeah great idea
Posted : 17/04/2014 8:22 am
 JRTG
Just don't use them or ditch the bag, you don't need all that stuff anyway.
Posted : 17/04/2014 8:24 am
(a) lots of bike jerseys out there with no pockets
(b) I try not to take a bag
Posted : 17/04/2014 8:27 am
Eh? You're complaining that putting stuff inthe pockets gets in the way of the backpack you've got on? Then don't put stuff in the pockets, put it in the backpack
On the occasions you don't have a backpack, the pockets are there to put stuff in.
Posted : 17/04/2014 8:28 am
JRTG - Member
Need the water though.
First there was light. And it was good. And then God said 'Lo, let there be bottles cages and bidons'. And there were bottle cages and bidons. And they were, well, adequate if you didn't want to take a back pack.
Or stuff a bidon in one of your jersey back pockets.
Posted : 17/04/2014 8:35 am
frame bag for easy-access?
Posted : 17/04/2014 8:37 am
Unless it's a long ride I use a little seat pack for minimal tools, put a couple of odd bits in my back pockets and carry a bottle on the frame. Get the right cage and they never fall out.
Riding without a backpack is very liberating (and a hell of a lot less sweaty)!
edit - ^ don't call them bidons though - can make you sound a bit try-hard.
JRTG - Member
Sorry I'm a MTBer, I have no idea what a Bidon is and my MTB doesn't have bottle cage mounts 🙂
Posted : 17/04/2014 8:38 am
Calling them bidons does make you sound like a muppet, but you could put a bottle in one of your much maligned jersey pockets... I never ride with a bag, much nicer!
Posted : 17/04/2014 8:40 am
What's the frame - sounds like an oversight to me (though some suspension setup make it impossible I guess).
Posted : 17/04/2014 8:41 am
Commencal Meta AM29
Posted : 17/04/2014 8:42 am
IMO a lot of "MTB" carries a mark up that is totally unnecessary. Shorts probably being the most obvious followed by tops.
Posted : 17/04/2014 8:44 am
Commencal Meta AM29
Ahh, don't worry it'll break soon enough and you can buy a bike with the right attachments 😉
And on the second day God created Google and other search engine facilities, so that man could ignore it and ask of others on MTB forums what it would have taken but mere seconds to discover for themselves.
Oh, and frame bags (as above).
Posted : 17/04/2014 8:46 am
I find them pretty useless for most riding but then I put stuff in the bag as I prefer that.
However, I've no started using a minimalist pack that is narrow so allows me access to the two side pockets. Mainly use these to carry a few bits of food so I can eat on the move.
Main reason I have them is that I also ride on the road and don't want two sets of jerseys. When they are empty you don't notice them.
Posted : 17/04/2014 8:50 am
Bidon/Chapeau etc etc = pretentious cockishness
Posted : 17/04/2014 8:52 am
It's surprising how hard it it is to find shorts with zipped pockets.
In the end, I found DHB Dynos. Zipped side and rear pockets, and nice slim cut so I don't look like i'm off to shred the gnar. Or, indeed, am particularly stoked.
Anyway, back on subject. I hate using jersey pockets. The weight of stuff in them pulls down causing the zip/collar/hem to dig in to the front of my neck
Posted : 17/04/2014 8:53 am
Ah, but epicyclo is a notorious weight-weenie.
sbd16v - Member
OK, maybe I should have been clearer. I like having pockets that are accessible. 3 at the back and none at the front doesn't work for me on a mtb.
I often use a saddlebag or more recently a frame bag. The idea of carrying a bidet is good for hygiene I suppose, but the frame bag gets in the way. 🙂
Putting the load on the bike is a good option, but it's a real hassle for lifting the bike over fences, through those fancy gates designed to keep wheelchair users off the trails, or over stiles (my right arm is weak once I lift over shoulder height). Which is why I prefer a backpack for most use.
BTW for short rides under 2-3 hours I don't need anything.
scotroutes - Member
Reformed WW now. Look at what I ride the most now. 🙂
Posted : 17/04/2014 8:54 am
the only thing I carry in my shorts pockets is a hankie and they don't fall out, zips or no.
The thought of landing on my keys or a multi-tool when I inevitably fall off is too painful to contemplate.
Posted : 17/04/2014 8:55 am
Wrong side of the bed this morning? Slightly strong responses for early on such a beautiful start to the long Easter weekend break and all riding opportunities it brings?
I had hoped people might pick up the deliberately biblically themed language, slightly tongue in cheek and with which I thought 'bidon' was a better fit than 'water bottle'.
In case of doubt, my above posts weren't meant to be taken entirely seriously.
Posted : 17/04/2014 8:56 am
 adsh
Must be a hell of a pack not to be able to access the outer 2 pockets?
I use 2 bottle cages, saddle pack, frame mounted pump and carry food and a gilet in my pockets. Works well for the XC stuff I like.
I used to have an issue with the fit of jerseys in that they were tight and shorts were baggy making me look like a puny weakling. Now I'm into XC I've ditched the baggies and view having no upper body as perfectly normal.
Posted : 17/04/2014 8:59 am
This - front pockets are useless for all but lightweight stuff. A cycle jersey is not the same as a walking shirt/jersey. You don't walk 10 miles hunched over looking at the floor!
Posted : 17/04/2014 9:00 am
 br
A couple of the guys have these type of Sacs, they have small zipped pockets in the belts - seem to work well.
http://www.tweekscycles.com/bike-accessories/hydration-packs/camelbak-charge-10-lr-hydration-pack
Posted : 17/04/2014 9:01 am
Neither were my comments
Oh and I'm working all over Easter weekend, so screw you! 😡
Houns - Sorry to hear you're working over Easter weekend - didn't mean to rub salt in...No riding at all? That definitely sucks.
Will spare a thought for you* when I'm on dry dusty local trails over the weekend
*this may not actually be true 🙂
Posted : 17/04/2014 9:05 am
loads of jerseys without pockets
loads of jerseys with pockets
tend to keep camera in one, etrex in another, and maybe a power bar or something in the 3rd. plus a camelback. no real issue accessing the pockets with back pack on. easier access to camera and snack. be a royal pita taking backpack of all the time.
depends what you prefer to ride i spose.
Posted : 17/04/2014 9:06 am
The thing with bottles on the frame, offroad, is that they do tend to get liberally coated in whatever crud you're riding through ime.
Posted : 17/04/2014 9:07 am
I understand the OP's gripe (when mountain biking). My bag doesn't have side pockets so if I'm bumbling along and want access to a wee snack it would be ace to have a chest pocked. Hmmm, the straps would infringe on that too.
Ohh well, i'll just have to stop and admire the view while scoffing my face.
Posted : 17/04/2014 9:10 am
Nope, no riding. Haven't been at work for last 11 days (7 days leave, 4 days sick) have been feeling crap all this time with a chest infection. Missed HONC, have a new bike built up and needing to be ridden too. I'm getting out of breath walking down stairs, never mind up, tbh doubtful if I'll be fit enough to work over the weekend anyway.
So yeah, I'm grumpy 😡 you can shove yer Bidon up yer 'arris, sideways 😡
I tend to keep my keys in my jersey pocket even when I have a camelbak on. So I like them 🙂
And I can't say I've ever noticed my jersey pulling on my neck.
Have a fun weekend, houns 🙂
Posted : 17/04/2014 9:14 am
*throws Bidon full of pisse at clubber*
Posted : 17/04/2014 9:16 am
Chapeau!
Posted : 17/04/2014 9:22 am
But Knowitalltrackworld is more useful than Google.
Posted : 17/04/2014 9:25 am
I got one of [url= http://www.wiggle.com/elite-corsa-scalatore-mtb-bottle/ ]these [/url]recently for just that reason.
Your jersey isn't tight enough!
Posted : 17/04/2014 9:44 am
Second the comments to dump the pack. Never bother unless I'm going to be out for more than a couple of hours riding. A bottle in the cage, a multitool and a phone. Don't really need much else.
A lot of the mtb specific ones can be quite a baggy fit for the size, which is a pain. Avoid them.
Posted : 17/04/2014 9:50 am
I just wear a T shirt for all my riding.
Posted : 17/04/2014 9:51 am
I always use the rear pockets, even if I'm wearing a pack. Can still access the left and right with a Camleback Mule. I keep my phone in the right pocket and a snack in the left - always!
It's lovely not riding with a back pack though, and when I do the pockets are invaluable. I wouldn't buy a jersey without them - incase manufacturers are listing in!
Posted : 17/04/2014 10:10 am
Pockets on the front would be pointless IMHO. Zip hip pockets on shorts are far more useful. Also, my Osprey has aligtle pouch on the shoulder strap that my multitool fits in.
Posted : 17/04/2014 10:24 am
actually keeping stuff in rear rockets? Was the Enduro fanny pack invented in vain?
eeh, just think, back in t'day, when someone created the Kangaroo pocket, and made it big enough for an OS map...
Posted : 17/04/2014 10:26 am
You guys do realise that if you wear a normal cotton t-shirt when cycling you will not die?
Posted : 17/04/2014 10:30 am
