Just a quick one.....who uses a jet wash to clean there bikes.
My old fella has just given me a low presure jet wash the nozzle is a very wide spray and looks like a mist, think its called a fan type spray.? It says it's 70bar Same as this
http://www.amazon.co.uk/CLARKE-STAR-POWER-WASHER-Litres/dp/B004Q0VA18
As long as its useded from a distance would it do much harm to the sealed bearings
Most normal jet washers are around 100bar +
Just don't concentrate it on sensitive areas like shock seals and sealed bearings and you'll be fine. I've got a mobi v-17 and none of the bikes I use it on have suffered any ill effects.
Use a stiff brush too, don't rely on the pressure washer to shift everything.
I use a Mobi v-17 straight after I've finished riding, washes the crud off without using any chemical cleaner. Just keep the lance away from bearings, headset and seals.
I use one of these (and have done for years) and save electric.
[img] http://lh5.googleusercontent.com/public/tOCiDvyZvsfA9SFyOZONyeP84qEEASkgXyRoRyUjRaTwHmwxWTcbutG1aL-rc-Fwb3qrC3g6aN7KoU6bsEnJwnniNI7iSSqAMlFyu6FSsHPkDc3t2V6L5Lvqxl0pgDTyYTJ_25h0GkRJJVXLZjd3Fta6JwDSepv6BZp0 [/img]
