What are people using as a gravel type tyre?
Bought a pair of 40mm Nanos, convinced that they would be fine and on my Pacenti CL25 rims they are wheel locking tight at the back. Bugger. Any alternatives that people know fit?
Not a pure cross tyre needed and must be tubeless.
Probably not helpful but I am running nano 40's in my pickenflick. Running them on crossmax 29er rims though. I think they are about 19mm inners. Give a decent amount of clearance.
Must be rims then. 20 mm inside and you would think that a wider rim, albeit 1mm would make them wide but shallow. These are too tall and are pretty well locking the rear wheel. I can't move the wheel in the stand.
I did read somewhere that early Nanos were bigger.
Maybe I should see if I am missing something.
Ah well. Checked again. The tyre is actually slightly compressed against the chainstay bridge. Size 54. Wonder if beiger frames have longer chainstays. What ever, the CX tyres are going on for the HONC.
I had 45mm(29'r 1.75) on my pickenflick(stans iron x rims)
Sounds more like you just bought an on-one 😆Ah well. Checked again. The tyre is actually slightly compressed against the chainstay bridge. Size 54. Wonder if beiger frames have longer chainstays.
Yeah
Wonder if they changed? Had mine since about Feb 2014
Well they originally didnt fit anything but mtb cranksets, then they kind of did allow a road crank just, then they now ship with road cranksets. So id guess there have been a few changes.
Google found someone who posted an [url= https://chinarello.wordpress.com/2016/09/07/rotor-3d-on-pickenflick/ ]Image[/url] which suggests there should be enough room to fit a bus through between the tyre and chainstay bridge.
Mine is a new one. Over an inch clearance between bridge on chainstays and seatstays.
Mine had a compact fitted the minute it landed. Well it was my 2nd as the first was stolen. The first (arrived in very early Feb 2014) also had a compact fitted. I hadn't believed that anyway but it does make me wonder. That pic looks different to mine I think. I'll dig it out later.
Now I am just curious. The gap in front of my bridge is 31mm front to rear and the bridge is a gnats over 19mm. How does this compare to others?
I did more or less the same thing as you Matt. I ended up with some panaracer gravel king sk 35s (they do 40s too which are bigger than the nanos) which measure 40mm wide when fitted. they are smaller in circumference than the nanos so didn't get so close to the BB giving much more clearance.
Cheers.
Width I can cope with but length? Nope. Actress/Bishop etc
