big frames and 26&#...
[Closed] big frames and 26'' wheels........?
 ton
[#1563586]
why do big framed bikes look a c*ck with 26'' wheels
do you think all frames bigger than 20'' should be 29rs?
Posted : 01/05/2010 10:25 am
They don,t
No
Your bikes look shyte cos you stick that crud ont back 😉
Although the Heckler was an object of true horror
Posted : 01/05/2010 10:30 am
 ton
i wont disagree.......
but you are only a short ar5e, so yours look ok. 😉
Posted : 01/05/2010 10:31 am
Tis true - and there are some really stoopid looking small 29ers out there too.
Posted : 01/05/2010 11:13 am
 Soup
Can't say it bothers me. I think smaller bikes with scaffold tube seatposts look worse. I'm sure some people prefer the 29ers, but having ridden one, can't say it converted me at all.
Posted : 01/05/2010 11:59 am
 GW
big frames all look shit irrespective of wheel size!
Sorry Ton but all your bikes are ugly, deal with it! 😛
Posted : 01/05/2010 12:05 pm
just keep buying big frames until you get one that 'looks good'
Posted : 01/05/2010 12:14 pm
Who cares as long it rides well
Posted : 01/05/2010 12:22 pm
 GW
but big 20"+ frames don't ride well 😐
Posted : 01/05/2010 12:39 pm
[i]GW - Member
but big 20"+ frames don't ride well [/i]
WTF?! Well i have ridden a 20" frame for years and not had a problem. Im sure others have as well... 😉
Posted : 01/05/2010 12:47 pm
Don't listen to these vertically challenged people ton, I happen to think your OP is right (not that that counts for anything!)
Posted : 01/05/2010 12:53 pm
Gates look shit. At 6'3 its a fact I have had to accept.
The cure is only a phone call away-
"Hello mr nicolai? Yes, I'd like a 24" tt with a st JUST long enough for full extension with a 400mm post."
Or buy bikes from companies who drop the tt and put on a gusset - some of the big turners look ok for this reason.
Posted : 01/05/2010 1:15 pm
I think there should be a rule that says your wheels should be 8" smaller in diameter than your inside leg.
Posted : 01/05/2010 1:27 pm
 Soup
We should of course all be riding 13" On-One's with a steel front end, ti lugs and a carbon rear end, 9" travel forks with 280mm discs, a 20" rear wheel and a 29" front using a 2 x 6 set up. That might be niche enough for everyone.
Posted : 01/05/2010 1:34 pm
