Had my Beto air tank for a year now it’s been fine. However after charging tank and opening lever to release air it sounds like it’s leaking out of top of tank(internally) rather than into tyre 🙁
Maybe something came off inside ? Anyone have any knowledge of these before I attempt to open it up
Does it still do it when connected to a seated tyre? I.e. connect it to something that doesn't leak and see if it is leaking from the tank.
Yes it’s borked 🙁 No issue I’ve emailed tredz hopefully warranty job
I’ve heard a few of these have gone pop. A mate had one that failed after a few uses so he’s now got an airshot. Very little to go wrong with those.
There was a recent recall of a different brand, similar design, because essentially the bond holding the plastic on could possibly fail. Bit of a safety issue, should be reported to the manufacturer.
I've got one, so I make sure the top is pointed somewhere else when I'm putting 120psi in it...
Airshot is my next purchase 🙂
