Best value trail bi...
[Closed] Best value trail bike at the moment to replace Specialized Camber Evo 2015
Learning to do it yourself is key. It will save you time and money. It can be stressful but then doing preventative maintenance can prevent the stress of your bike having problems before a big ride.
Buy a book like the Park tool maintenance manual and get stuck in.
Posted : 09/04/2017 8:29 am
Only need a chain a year? You ain't riding enough
My chains / groupsets seem to last 2 years minimum 😳
My 2006 Hardrock is on the original Deore kit, Surrey Hills for 2 years, loaner bike, daughter and son-in-law commuter, back to loaner and now pretty buggered (wntertaining movement in headset, bb, wheel bearings) !
OP new groupset or min chain and cassette every year, brand new brakes £100 (xt) then oads once twoce a year, suspension picot bearings once a year max. Given your conditions that what you should expect. A new FS around £1500 is going to have cheaper components that don't last and are harder/more costly to maintain. Thats the whole point of kit like Hope, you pay more updront but it last longer amd is easier to maintain.
One final thought, at £1,500 personally I'd look at a hardtail with better kit on it and imo it would be more suitable given the mud etc. 120-140 travel to handle to rocky descents maybe. Plus spend £200 on a 1-1 session with Jedi (Tony) at UK Bike Skills - THE best money you'll ever spend on your mtb-ing.
Posted : 09/04/2017 8:31 am
Fully rigid 27+ or 29+/half fat and use 2 or 3 chains in rotation. I like the idea of a stainless narrow wide chainring.
Posted : 09/04/2017 8:36 am
So is it completely uneconomical to run any FS in Winter in the UK ? (Unless you stick to the drier Trail Centres) ?
I 0nly ride FS (though I have 2) all year round, though I probably ride more in winter tbh, as nice weather means family stuff too.
Keep everything lubed, use a decent lube that doesn't hold all the gloop - rock n roll blue for me - bearings greased as above too. IMO a GX 1x11 is a great set up for winter, really solid steel cassette.
Keep on top of the maintenance, I quite enjoy an evening servicing forks etc.
There's a surprise eh? You've no time to ride your bike, always on here spouting nonsense. :mrgreen:
Posted : 09/04/2017 9:48 am
Learn how to pop the seals off your bearings (surprisingly easy with a dental pick) and pack them with marine grease before squeezing the seals back in place. Use Mobil XHP222. With that in them it's very hard for water to get in so your bearings will last WAY longer.
Posted : 09/04/2017 10:16 am
I don't ride my FS much in winter however my HT is used a couple of times a week, in all weather. 2x10 XT drivetrain lasts about a year. Pads need changed every few months, fork (Reba) goes to TF Tuned annually. Reverb breaks and gets warrantied every 18 months 😀
That's been the pattern for the 4 yrs of that particular bike and it's as good as new.
I am considering using FS all the time, as not getting any younger, but do wonder how much work would be involved in maintaining shock and linkages (current Giant Anthem)
Posted : 09/04/2017 10:21 am
iainc - Member
I got two years out of my anthem linkage. Thought it was basically OK, but on taking the shock out to replace a bushing, couldn't believe how much movement was in the linkage. Rickety as anything, so had to replace [ten bearings, awkward job first time round].
So I think if you're predominately just pushing the miles out, then the maestro is fine to run over winter. If you're descending hard, racing etc, or have low tolerance for flex in a bike, then best to park it up.
Posted : 09/04/2017 12:28 pm
Is the anthem bearing swap difficult or just time consuming?
Is there a special tool that makes it a lot easier?
Posted : 09/04/2017 12:47 pm
It's OK - I was doing it first time the night before a race, so it felt like more of a difficult job than it should have done.
You can buy a set of blind bearing pullers, or use a socket set and a vice. There is one particular pair, though, that is hard to manipulate in a vice - the smallest bearing on the top of the seatstay. I had to reach for the hammer in this case.
There was a recent thread on it here and a poster [stoddys] was v helpful in sending through some tips.
If I were doing it again, strip the bike down, clear the decks, take my time - I think it would be easy.
Posted : 09/04/2017 1:47 pm
tpbiker - Member
Go single pivot to save on bearings if you need a full suss
Nah, don't, the saving is bugger all. Some badly designed bikes do go through bearings but otherwise, bearings are one of the smallest maintenance costs for a bike.
Posted : 09/04/2017 1:55 pm
If you ride your bike often and all year round it's not unusual to need bearings changing on an annual basis which can cost upward of £150 , if you also follow manufacturers recommendations you should probably service your shock at the same time which could well cost another £150 so costs are not insignificant .
Posted : 09/04/2017 4:20 pm
If you get a bike that uses common bearing sizes and can be relatively easily changed yourself then that can save you a lot on pivot servicing. A set of eight bearings for my Spitfire is under £30, including the marine grease I add to them.
I bought an RRP bearing press and the proper tools for under £100 but you could make your own version with threaded rod and nuts and sockets for a lot less. Makes it an easy job, just a bit time consuming - I'd expect it to take 15 minutes per bearing, so two hours for the lot (starting with a clean bike).
If you ride a lot then sadly you have to either pay someone else or spend time on maintenance - bikes wear out. The mileage relative to maintenance may seem low compared to cars but it isn't relative to hours of use.
Posted : 09/04/2017 4:48 pm
Ramsey Neil - Member
If you're prepared to pay too much, sure.
Posted : 09/04/2017 6:12 pm
My yeti was bloody expensive for bearings, but it wasn't 150 quid!
Posted : 09/04/2017 6:24 pm
Northwind - Member
I know that you can do it yourself and you can get bearings from sources that are cheaper than buying from a bike manufacturer but my comment was really directed at the OP who admits to being not great at doing it himself and the specialized bearing kits are £70 for that bike so that only leaves about £65 labour plus VAT and you have your £150 .
Posted : 09/04/2017 8:03 pm
I think if you're spending 1.6k in a year on maintenance then it's not the bike's fault. As was discussed at length on your previous thread your mechanic/s seemed to be taking the piss with costs and replacing stuff that wasn't needed.
Also, you need to have a look at how you're riding and treating your kit. Sounds like you're not doing simple cleaning and maintenance very well.
My current fave ride? A Dialled Love Hate single speed. Almost full 2nd hand....£100 frame and headset, £75 suspension forks, 10 year old Middleburn chainset, mismatched wheels from a bike jumble, Deore disc brakes (well abused!) - probably cost £350 all in.
Looks shonky, but runs like a beaut. Very low maintenance costs too!
Posted : 09/04/2017 8:20 pm
I've been following this thread, along with the sister thread about how much the OP is spending on maintenance.
To be blunt, buying another bike isn't going to fix those issues. If the OP is constantly handing over money to a "mechanic" then I suspect that is the root of the problem.
The OP also has been very quiet as to whether they've contacted Specialized for comment - I've owned Specialized bikes for fourteen years, their warranty dept look after you and are more than happy to fix stuff with minimal fuss all round. I'm on Specialized number four and it's been brilliant.
Something really doesn't look right about this thread at all...
Posted : 09/04/2017 8:30 pm
My pulled from the air (or another A-word) rule of thumb is
£1000 budget hardtail
£2000 budget full-suss
£1500 is mid-range but as I said given OPs experience and conditions I'd choose a hardtail with better components especially BB and wheel hubs. As above Deore cassette/chain/brakes are just fine amd who needs lightweight kit in a bog !
Posted : 10/04/2017 9:21 am
A ss cost me about £200 all in, though I had some 26" wheels.
Wiltshire mud destroys bikes, you just learn to work around it.
Posted : 10/04/2017 11:12 am
I can't think of much to add.
Dragging a decent mtb through seven sorts of rubbish on a regular basis will mean stuff breaks. I too have a 2015 Camber Evo. This has been generally reliable in my view but has very few original items, my forks are currently in need of replacement, dropper post is still working, cranks and brakes are original.
I am on probably 3rd or 4th drive train, 3rd set of frame bearings, 4th bottom bracket, second set of wheels, you get the picture.
The bike has not had an easy life, BC Bike Race, various xc and marathon events, a host of trail centres, 12 months of neglect in Ireland, trips to Madeira and Italy for uplift riding....... more than 4,500 miles of not easy off road riding.
The bike is great and still puts a smile on my face. Keeping it all running smoothly and efficiently costs time and money.
And to answer the question - have a look at getting a Turner and using the grease ports regularly to keep all the bushings running smoothly through the grot. You will however have the same issues with every other component. Try for Hope of King components (hubs, bottom brackets and headset), SLX running gear and Hope Brakes. Oh and no dropper. Then learn how to maintain and lube your suspension forks and do it.
Posted : 10/04/2017 11:36 am
mountain bikes are heavy, slow, inefficient and, as you've discovered, expensive to run.
Yes, it is.
Road bike. Sorted.
Posted : 10/04/2017 12:15 pm
Page 2 / 2
