Hello,
Ive got a set of pikes that need a spot of touching up due to cable rub etc
Any recommendations on best paint to use?
Cheers Graeme
any car touch up paint if it's spots and chips, a spray if its a bigger patch and you want to be tidy and can be bothered to mask stuff off.
Or clear lacquer for rat-look.
If they are matt black finish then the Hycote paint pens are good - pro tip, don't use the brush in the lid - put a bit of the paint on something to work as a pallette and use something to carefully wipe the paint on. It's less likely to blob that way
A little piece of handlebar tape works well for this as they have a feathered edge
touch up paint it is then got some of that kicking around 👍
