Best shock used or ...
[Closed] Best shock used or previous years model under £200?
[#5314231]
Answers on a postcard please - 200mm x 57mm
Thinking Fox RP23 or lower end Rock Shox Monarch maybe?????
Cheers.
Posted : 08/07/2013 4:50 pm
Problem is unless it's tuned for your frame it'll likley be pants whatever you get. And you'll need new bushes/reducers.
Save up £100 more and get soemthing new from TF/MOJO/LOCO
Posted : 08/07/2013 4:58 pm
I recommend a monarch as they are completely user servicable... you can even buy the shim stacks for the various tunes.
Posted : 08/07/2013 5:19 pm
Brand new Monarch RC3 plus from TF Tuned is £199 and I think they'll set it for you and your bike in that price. Can't go wrong.
EDIT - whoops! It's a 51mm stroke, not 57 though.
Posted : 08/07/2013 5:34 pm
Ended up getting a new RP23 for £170 - just as a stop gap. Has to be better than the Spesh AFR I accidentally (but with little regret) buggered the other day.
Posted : 10/07/2013 8:23 am
From CRC?
Had mine a couple of weeks and not wholly impressed so far. All set up with correct sag etc but still bounces on lock and generally isn't working as I expected.
Will persevere ... might end up having it Pushed it need be.
Worth checking out [url= http://www.ridefox.com/fox_tech_center/owners_manuals/07/eng/rear_shocks/float_rp23.htm ]guides [/url]like this.
Posted : 10/07/2013 9:22 am
[quote=spacemonkey ]Ended up getting a new RP23 for £170
From CRC?
Worth checking out guides like this.
Did you get the right tune for your frame?
Posted : 10/07/2013 9:25 am
From CRC?
No, from fleabay - CRC didn't have my size.
We shall see....
Posted : 10/07/2013 9:30 am
Not far off IIRC, but the plan was just to get hold of one in the first place and then send off for tuning/Pushing if necessary.
It's totally ridable and the geo is fine - only altered a tiny bit.
Like TAFKASTR says, I'll keep fettling and see how it goes ...
Posted : 10/07/2013 9:44 am
If i were you i would get an float r/rp2 and have it tuned by loco for your frame. No real need for propedal on the enduro (after tuning the compression is upped anyhow)
Posted : 10/07/2013 10:11 am
Needed something asap Rob. Tft only had big bucks models in stock in my size. On both Enduros I've owned both with proprietary shocks, pro pedal has most definitely been required.
Whilst I understand shocks can be tuned for frames/rider, surely it can't always be necessary. Does no one but new shocks as stock?
Posted : 10/07/2013 11:55 am
Well, shock has arrived - tune is as follows - rebound F, compression M, boost valve 175. Anyone used a similar tune on a similar bike?
Posted : 10/07/2013 5:12 pm
I had a stock RP2 HV on my Enduro, medium rebound and compression. I loved it and got on great with it, swapped it for a DHX5 coil and now progressed on to a RC4 as I wanted something more aggressive.
Posted : 10/07/2013 8:07 pm
