What do you use? I like the angry wasps nest noise mine makes so I don’t want to go too thick I guess. Standard wet lube work well enough?
Posted : 06/07/2021 2:59 pm
What kind of freehub is it, ratchet orr pawl? brand and model?
Posted : 06/07/2021 3:04 pm
Depends on the freehub. Some need greasing, other's need light oil.
In general, I just use GL5/EP90 oil unless there's something else recommended. This is probably overkill, I doubt the pawls are under enough pressure to actually make use of the additives in it.
Posted : 06/07/2021 4:28 pm
It’s an Industry 9 pawl freehub
Thanks
Posted : 06/07/2021 4:45 pm
Posted : 06/07/2021 4:51 pm
