Best lights for £20...
[Closed] Best lights for £20 budget
 stec
[#1772374]
Front and back i know there are lots out there but any good opinions
Posted : 05/07/2010 10:32 pm
Posted : 05/07/2010 10:34 pm
 stec
Posted : 05/07/2010 10:41 pm
Presume you mean a commuting set.
These are good:
[url= http://www.wiggle.co.uk/p/cycle/7/Cateye_HL-EL130_and_TL-LD130_Light_Set/5360045566/ ]http://www.wiggle.co.uk/p/cycle/7/Cateye_HL-EL130_and_TL-LD130_Light_Set/5360045566/[/url]
The mrs picked up a set from tesco that are really bright and even cheaper
[url= http://direct.tesco.com/q/R.202-3716.aspx ]http://direct.tesco.com/q/R.202-3716.aspx[/url]
Posted : 05/07/2010 10:50 pm
 stec
Thanks nick the cat eye ones look the ones
Posted : 05/07/2010 11:00 pm
IMHO £20 isn't really enough for two decent units. A Cateye rear such as LD600/LD610 will get you seen in most conditions (you [i]do[/i] want to be noticed, right?) though the little LD130 / LD150 models are useable. All run on 2xAAA.
On the front the tiny Cateye EL135 (2xAA) is the minimum I'd settle for. The larger models, the EL320 and up, have a bright spot but poor spread. [url= http://www.thephotonshop.co.uk/page22.htm ]Fenix LD20[/url] (2xAA) is waaay better, waterproof and a truly worthwhile investment. Yes it blows your budget to pieces but unlike the others you are unlikely to feel the need to upgrade after a few trips home from the pub.
Posted : 05/07/2010 11:08 pm
