I've tried a few brands now. The Bike Shield stuff that's packed like smoked salmon is quite good but it's a waste of money because it comes in a load of pre cut shapes that you never use. I recently bought some sheets of Fox frame protector from my LBS but that only lasts for about 1 or 2 rides before it gets crap underneath it and starts peeling off !
I'm looking for some descent tape/protector that you can cut to size and shape and that stays on (around it's edges too) and can resist rock strikes, especially under the BB and on the crank arms.
Any suggestions please ? (There's been a few on Fresh Goods lately on the ST site, I'm guessing their building up to a review slot (?))
the stuff from biketart is holding fast on my covert... came in a big roll and was nice and easy to apply using the hot water technique.
Dave
I just used a load of Tesa tape of eBay and found it way better to work with than the paragon tapes. I realy rate it, the stuff is a bit thicker and go's on a dream with soapy water.
Best stuff I've had was from justridingalong a few years back, less tape, more like sticky clear rubber, formed over awkward shapes really easily with a hairdryer.
I've found Biketape from Biketart to work the best for me.
I've used at least 3 brands of tape (plus the free ready cut sticker packs that have come with Spesh & Giants), and the best by far has been the stuff from Justridingalong - quite pricey, but really good.
Biketart tape for me. Bought a couple of metres, thought it was expensive at the time, but still have half left and have done all rub and bash points on 3 bikes, including an Orange 5 swingarm.
Biketart tape best by far.
Not the cheapest - but easily the best.
Thanks for all the tips. Never seen the any with the hot soapy water method before !
Hi Gary, met you sunday coming down from Skiddaw as we were going up, had a laugh but it really poured down later on.
I bought Oxford 1mm clear heli tape very strong, got to put it on with a hair dryer to soften it for nooks and crannies, comes in a large sheet around £20.00 i did the lappy back end on both bikes.
Mark
Biketart tape for me as well, tried a few others but its defintely been the best of the bunch.
Go to TAPE SHOP like Viking tapes etc and buy 10x as much tape for the same price. It isn't a bike product just marked up like one!
Why's it called 'helicopter tape'? Always wondered 🙄 😆
if you unravel it and spin it around your head, you'll find out.
wish i'd found this thread before buggering up black cranks. not that it matters.
does the finish on SLX cranks rub off btw anyone know?
Apparently they use it on the edge of helicopter blades to strengthen them. 🙂
Tape here (they are all the same stuff really)
Some heli tape are thicker than others - and thicker is def not better.
Smiff: SLX cranks seem to stay pretty for ages - mine are three years old and look new (not too much mud/wet grit here though). XT's are scuffed up in less time..
i just use the tape we use on the leading edge of wind turbine blades...nice to pick up the roll ends! 3M i think
bampot thanks, i thought the SLX finish looked better. thinking of changing, not because of that, just i've damaged the axle on my old LX and SLX is a pretty good deal.
btw guy on ebay paragontapes i think, has matte finish tape. might look better on lots of parts..
bongo136 - Member
It's used on the leading edge of rotor blades to protect against sand/dust and rain erosion.
Actually called anti-erosion tape.
I bought from the guy there, really helpful and useful.
I contacted him through the contact and im sure you can buy directly like that!
Good responses here, yes they also use clear adhesive tape in F1 to protect key areas, the military (NATO) spec various grades for various applications and the brand is typically 3M. Be aware of cheap imitations. You can buy 1m lengths of 3M "leading edge tape" from Demon Tweeks (the motorsport division of Tweeks Cycles). Alternatively I can sell you 1m lengths x 100mm for £15 including postage, NATO spec 3M branded tape.
JRA tape has worked well for me. The last bike has used it for about 4 years and the previous bike must be about 7 years I reckon. Clean the frame, IPA, and then warm the tape when applying. I pre warmed the frame a bit last time as well if that helps.
http://www.justridingalong.com/trail-stuff/copter-tape-frame-tape.html
I bought some 3M pukka 0.4mm thick stuff from some motorsport place, and if I was going to do it again I would get a thinner tape for sure.
BTW don't ask to Heli tape in A certain bike shop in Totnes, Devon. You get a stern reply that no we haven't got and don't call it heli tape!
ok. I just got a new bike and want to get helicopter tape on it for protection. Any ideas how much of the stuff I will need before I order too much / little?? It's a 17" bike if that helps?
Hi wavejumper, I've got an 18" Orange Five Am and I covered the main points (headtube, toptube, downtube, swingarm, seattube etc) with a 1.5m length of 4" wide tape
